Question about Panasonic AG-DS555 S-VHS VCR
Seems like TBC won't lock, blue cast, picture unstable, weird colors, no contrast
I just got this deck and I love it. I'm a ham guy/computer tech., have solder station, can perform surgery.
You mentioned replacing all the caps on the vid boards. Before I do this, I notice lots of internal trim pots. Is it possible the unit needs a tune-up? Seems to get more stable after warmed up -- jog/shuttling back and forth will eventually get it to lock on. Does it playing tape as well as video in, so I'm convinced it's in the output somewhere -- TBC, video out. This deck won't let you turn the TBC off? Tried the setup procedure from the user manual for the TBC. Any help appreciated. Sounds like you really know your stuff. Actually, mine is the AG-DS550. Cheers, Duncan McAllister
  • Anonymous Nov 26, 2008
    I have DS555 and it's not recording properly: slightly shaky picture.
    Champion:
  • 221 Answers
Change in stability after warm-up is a sign of defective capacitors. the DS550 and DS850 both are notorious for capacitor failures. don't touch the trim pots unless you have a service manual and a wfm/vectorscope.
Posted on Nov 24, 2008
Transmit audio has a warble distortion
you will be better off taking this to a tech considering it is a ham radio also. he can set the freq and put it on a distortion meter also to find out the problem.
Mar 13, 2014 | Galaxy Radios DX-99V 40-Channels Base CB...
What is the purpose of an R2 filter?
Each filter intensifies its color and darkens others, especially the color opposite on the color wheel. They're not of much use in color photography, unless you want weird color casts, but they come into their own in black&white photography.
For example, a red filter intensifies red and darkens blue. It can make a sky look almost black, making clouds pop out. Similarly it can darken foliage. A green filter on the other hand will brighten foliage.
If your camera can take black&white photos, try taking pictures of a red rose with green leaves with and without the filters. With one combination the rose and the leaves will be the same shade. With a red filter the rose will be bright against the dark leaves. With a green filter you'll get a dark rose with bright leaves.
With digital photography you can achieve the same effect in postprocessing, but some times its easier to get the result in camera.
Apr 28, 2012 | Quantaray 55mm Red R2 Lens Filter
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
I have a canon EOS 450 and on a recent trip to Iceland, clear light but lots of lying snow, most of my shots came out with a very blue cast. I had a UV filter attached. Can you help?
The UV filter should have been OK, in fact it would have decreased the blueness - The OES has a 'snow' setting I thought - what this does is change the white balance.
If your pictures are now on the computer try and change exposure setting , and also contrast.
By reducing Colour Saturation (removes blue) you will also loose some sky color.
Ray
Feb 03, 2011 | Canon Cameras
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Screen is now a weird color
The problem might be in the cable. Try to reconnect it to your machine. Also try to set your color settings on the monitor itself, so that all the colors are equal.
Sep 26, 2008 | LG Flatron L1750S 17" LCD Monitor
No colour at playback when tbe switch is on
The DNR boards for these machines can go bad and produce a black and white picture. Try swapping the DNR board.
Apr 30, 2007 | JVC BR-S822DXU VHS/S-VHS playback VCR
Panasonic AG-DS555 S-VHS VCR Logo
359 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
