Epson stylus s20 printer not working. Only 3 weeks old. Status monitor window says "printer not ready to print" Ink tank icons are blanked out as grey. Cannot find the device in device manager. Cannot uninstall or install the driver.
  • 4 more comments
  • Anonymous Nov 12, 2008
    I have the same problem as the printer status says "Ink Cartridges Cannot Be Recognised"
  • Anonymous Nov 17, 2008
    I gave up cos this printer was useless with ink and got a refund now I can't uninstall it
  • Anonymous Jan 01, 2009
    I bought some compatible catridges on ebay and it's not recognizing them, hence refusing to print.
    They do fit and are the right ones, on older epson printers it just said 'do you want to proceed anyway?' in this situation... now I'm not sure... I suspect there may be a way around this, a way of tricking the printer or overriding the strict corporate buy epson cartridges message... they did work briefly and inconsistently, before it got arsey with me.
  • Anonymous Jan 02, 2009
    brand new printer, wont work properly in fact at all even with the genuine cartridges fitted. p***ed off!!
  • Anonymous Feb 26, 2009
    I bounts an S20 and withing days it was telling me the black cartridge was not regognised (the one Epson supplied with it). What sort of **** is this Epson?
  • liamsmythe20 Mar 22, 2009
    i have the exact same problem, i had it a week and it says it cant recognise the black cardrige and is it the original!
    TAKE IT BACK, I CANT TAKE MINE BACK!
I purchased a Epson S20 printer and it does not recognise the new ink which is Epson ink what should I do
GEOFF
Posted on Jan 14, 2010
I have an Epson CX4800 printer. It won't print because there is low ink. My laptop indicates that the ink is low, but won't tell me which color it is. How can I connect the two so that I know which ink is...
What OS are you running? Did you install the full Epson software before you connected the printer to the computer? Is the Epson Status Monitor running on the computer?
If you didn't install the full software or installed a generic Windows driver, uninstall the printer. Then disconnect the data cable. Reboot the computer and go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1326618163.1304563464@@@@&BV_EngineID=ccfkadfdhhmeimgcfngcfkmdhjidfmh.0&cookies=no&oid=58606&prodoid=56291067&infoType=Downloads&platform=All . Download and install the appropriate file from the section marked Drivers and Utilities Combo Package.
If you have a Windows OS, if the Epson Status Monitor is running, the icon for it should be present in the lower right hand corner of the screen (status/Notification area). In Windows 7, it may not be immediately visible, click on the double arrow symbol. Then double-click on the Epson Status Monitor icon and the status window should appear with the ink level indicators in the bottom half of the window.
For a Mac OS, open the Applications folder, then select Epson Printer Utility. Select your printer and click OK. Then select the Epson Status Monitor to get the ink level window.
I hope this helps.
(this is generally faster than using the No Ink spot inside the printer. However the ink levels are approximate.)
May 05, 2011 | Epson Stylus CX4800 All-In-One InkJet...
How do I know WHICH of the ink cartridges is out?
I found this on the Epson Web Site. If you find this information helpful, pls rate me.
You can download the Reference Guide with pictures and all.
http://files.support.epson.com/htmldocs/r220__/r220__rf/index.htm
Windows
You can check the amount of ink remaining in the ink cartridges using EPSON Status Monitor 3 or the progress meter. Refer to the sections below for details.
EPSON Status Monitor 3 Access EPSON Status Monitor 3 in one of the following ways.
  • Double-click the printer-shaped shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar, see the section below.
    font26.gif See Monitoring Preferences
  • Open the printer software, click the Maintenance tab, then click the EPSON Status Monitor 3 button.
A graphic displays the remaining amount of ink.
If any of the ink cartridges installed in the printer is broken, incompatible with the printer model, or improperly installed, EPSON Status Monitor 3 will not display an accurate calculation for the amount of ink remaining in any of the ink cartridges. Be sure to replace or reinstall any ink cartridge indicated by EPSON Status Monitor 3.
Pls rate me. Thanks and Good Luck.....
Feb 09, 2010 | Epson Stylus Photo R220 InkJet Printer
How do you fix an epson s20 printer when it says ink cartriges cannot be recognised?
  • Remove the tank.
  • Connect a hose directly on the inlet ink.
  • Locate the sensor of reservoir and press it to make as if a cartridge is available.
  • Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
  • Replace the tank up and do a test print.
  • Repeat the procedure several times if the nozzles are clogged.
Jan 17, 2010 | Epson Stylus S20 InkJet Photo Printer...
The red light has come on to replace the ink cartridg, i only use black ink then i tried to reset and the red light is still on and it will not print. the colour cartridges are about 3 years old???????...
Check status monitor? See difference of chip reach ink out and not recognized. Reset chip that ink level reach ink out. Also check chip connector at ink tank and at chip itself. Plug ink tank securely. Check status monitor again. If still not resolved, try to use anither chip.
Aug 18, 2009 | Epson Stylus C86 InkJet Printer
Status Monitor isn't hihglighted so I can't check
This can only be done by getting a new status monitor software . Follow my instructions:- STEP 1 - Install the Epson StatusMonitor software. This program comes on the CD included with the printer. It can also be downloaded from the Epson Web site ( http://download.cnet.com/Epson-Status-Monitor-2/3000-2116_4-10024738.html ).
STEP 2 - Open the Epson StatusMonitor program in any application (such as wordprocessingmag-glass_10x10.gif, spreadsheets or Web browsers) that allows you to print. Click on the "File" menu tab in the control bar of the application.
STEP 3 - Select print or page setup from the "File" menu. A dialog box will open. In that box, click on the "StatusMonitor" icon, which will open the "Epson StatusMonitor" dialog box. Also, you can click on the "Utility" icon and then the "Epson StatusMonitor" button from the "Utility" dialog box.
STEP 4 - Click on the "Update" button to update the display (if you do not think these levels are accurate) when the "Epson StatusMonitor" dialog box displays the relative ink levels for each cartridge in the printer.
STEP 5 - Go back to the "Print" dialog box to change the way that the StatusMonitor utility monitors your printer and ink levels. Click on the "Utility" button again.
STEP 6 - Click on the "Configuration" button in the "Utility" dialog box. The open "Configuration" dialog box will let you adjust settings such as ink level warnings and ink level monitoring before each printing.
Aug 13, 2009 | Epson Stylus Photo R200 InkJet Printer
Printer has ink BUT has stopped printing
It is your print head, not ink cartridge
It is reasonably easy to change yourself - google for Stylus C70 printer head
Aug 05, 2009 | Epson Stylus C70 InkJet Printer
Red lights flashing. I dont think the ink is out and i did try taking them out following the instructions and put the same ones back in but it still won't print and the light is still flashing, will it...
Printer wouldn't print if red light flashing. Check status monitor for detail? Are some ink not recognized? Do replacement procedure from status monitor on "How to...". Unplug all ink tank. Plug only one ink tank . See status monitor. Is ink tank recognized. repeat procedure, and add ink tank 1 by 1. How about status monitor then?
Jul 09, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Epson s20 genuin ink not recognised
I think the problem is in your windows, try to reinstall your windows. I suggest, don't reset the original chip, cause it's damage the chip.
May 29, 2009 | Epson Stylus S20 InkJet Photo Printer...
Status Monitor 3
In reply to SOLUTION #1 by Basti i have vista and have forced it to work with this status monitor 3 software i will post how i did it now.
First i downloaded the status 3 monitor so that i could fiddle with the programs and files inside from this link here
http://driverscollection.com/?file_id=24410
Ill skip right to the part on how to fix it you extract the file you just downloaded open the folder it went to right click E_SIINS2 with a bandaid icon goto properties then click compatibility at the top of the new window that opened check the box run this program in compatibility mode for: then in the drop down box below that windows xp (service pack 2) also i checked at the bottom run this program as an administrator and boom it worked i can see my ink and everything.
Jun 14, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson C60 Stylus Status Monitor Does Not Work On Windows Vista
I ve been having the same problem with my Epson 1290 and Windows Vista! It works fine but I cant get the status info on my ink levels. Its so annoying when u run out of ink the LED on the printer goes on but you dont know whick cartridges to replace! I hope Microsoft and Epson get this sorted out because it so annoying and I end up spending more money on inks than needed! I read someone had similar problem, installed the 1290 M driver (via Vistas set drivers) but it didnt work for me!
any other suggestions?
Apr 18, 2008 | Epson Stylus Photo 1290 InkJet Printer
1,529 people viewed this question
jasbo
jasbo
