Question about HP Pavilion dv1000 Notebook
Turning on &sterio problems
I am having problems with turing on my laptop and also the speakers have stopped working. I also have problems starting up my HP Pavilion dv1000 Notebook PC. I have to press the start button many times before it will start. Sometimes after pressing the button 20 or 30 times and it hasn't started, I can press and hold start button for 4 or 5 seconds and can, by then, get results. Would sure like to fix this problem before I can't ever start it period.
Thanks, Linda Pond
Hi, my problem was that I had trouble turning my laptop on. It had been getting worse over the last couple of years. It was suggested that the power button should be replaced. While searching the HP site on how to do this, I ran across a solution that said to take out the battery, unhook anything else that might be connected to the laptop, and then press the power button for around 10 seconds to drain all remaining power out. Then put battery back in and try to turn on. It worked! My laptop now turns on and off just fine! Hope this can help someone else....Linda P
Posted on Nov 20, 2008
How do I get my Gateway laptop to boot?
F12 BOOT DIVICE MENU WEN LAPTOP IT TURING ON
Jan 11, 2013 | Gateway Computers & Internet
I was in the middle of playing a song and all speakers suddenly stopped working cannot figure out why.
If it will turn back on and it jus keeps doin that,,,blow sterio out ,,,dust will cause that,,also check ,,if you have to replace speaker wire,,one little place in wire will do that everytime,,new sterios do that to protect reciever,,auto shut off,,,
Nov 04, 2010 | Creative Labs Inspire P5800 Computer...
Partly green screen on the right side of my laptop computer
you may be close to a strong magnetic field ie tv or sterio speakers ect move away from magnetic source some tv engineers or com engineers have a wand type tool thats moved over the screen which will restore it or sometimes you just wait and eventually it will right its self.
hope this helps.
Apr 26, 2010 | ASUS EEEPC900BLK Netbook
LAPTOP IS MAKING WIERD SOUNDS OUT OF THE SPEAKER
dear sir,
this types of problem come from the sound section of the laptop motherboard. your laptop contains sterio sound system. problem is one channel of the sound circuit faulty. but it is too dificult to repare it.
u can do one think, u can stop one channel sound by using sound balancing option from the task bar volume control option.
also u can contact with Acer service centre.
Nov 09, 2009 | Acer Aspire 5602WLMI Notebook
Turing left is very hard and turing right isnt. is the powersteering broken?
you have internal problem with the rack and pinion assembly ,needs new r&p installed they mainly come remanufactured ,not cheap! good luck
May 06, 2009 | 2000 Chrysler Concorde
Sterio Speakers
have you tried the Realtek Site? it has the list of drivers for this card.
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
download and install the first one. its for vista and windows 7
you device inside the laptop should be for a
Realtek® AC'97 Audio Device
so this should work for your machine. if you still continue to have problems let me know. just make sure you have also got the correct chipset utility for your board since you have upgraded.
Good Luck!
Ruben
Aug 18, 2008 | Sony VGN-A190 Notebook
What is it doing exactly when you start it?
Jul 18, 2008 | HP Pavilion dv6000z Notebook
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
I have a philips cd player model# FW-C70/37, that has power going to it but has no sound coming from any of the speakers, nor will the cd changer open.
cd players work without use of volume controls coax cables hook up's and then by setting reciever to proper button so sound can come out
you might have had a power surge that fried your system but lets look at easy stuff first
fuses
lines in properly and connected
test on an old sterio with speaker hook ups and test your speakers by plugging in to old beat box
make sure wires are not scorched
turn on receiver fm see if speakers work change channels to sterio and mono settings if speakers start to work on sterio or mono setting chances are power surge blew out your system
hope this worked
May 07, 2008 | Audio Players & Recorders
Use the logitech sistem with lcd tv
hey no it wont work in full 5 .1 cuse samsung tv has rca outs use rca to mini sterio jack but your speakers syetm for pc is set up for fronts rears center chs 3 sepret sterio plugs for pc so u can only use one of these sets front with woof not all 5 nope unless ther was a controller in it that ran off 1 sterio plug to controll all 5 built into the logitec speakers but i pretty sure 3 sterio plugs right ? u understand best best dvd samsung x 40 those rock
Jan 09, 2008 | Logitech X-540 Computer Speakers
HP Pavilion dv1000 Notebook Logo
125 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
