Question about Handspring Treo 90 Handheld
Treo 90 I can't clear this msg: This is in a fatal alert box memorymgr.c,line4415,invalid handle. when I touch reset from the screen nothing happens?
I cant clear this msg. memorymgr.c,line:4365,NULL handle
Posted on Jul 20, 2009
When i try to sync i get a Fatal Alert MemoryMgr.c,Line:3751,Free handle?
To get rid of the Fatal Alert, perform the Hard Reset on the device.
Note:
A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings.
Follow the steps below to perform a hard reset on your device.
  1. Open your handheld.
  2. Press and hold the power button on the top panel of the handheld.
  3. While holding the power button, use the tip of your stylus or an unfolded paper clip (or similar object without a sharp tip) to gently press and release the reset button. (The reset button is the tiny hole labeled Reset on the back of the handheld.)
  4. Wait for the Palm Powered logo to appear; then release the power button.
  5. When prompted that you are about to erase all the data stored on your handheld, press Up to complete the hard reset.
  6. When prompted, complete the steps to align the screen.
Sep 21, 2009 | Palm Tungsten E2 Handheld
How do I do a hard reset? I tried a soft reset with no luck. I have a fatal alert: memorymgr.c, line 3632, NULL handle
Hold power button while pressing reset button release release the power button when you see YES/NO confirmation to erase all data. Once you choose Yes, It will set everything to factory default. Personal data will be erased.
Jun 30, 2009 | Palm Zire 72 Handheld
Fatal alert memorymgr.c,Line:3732
Just happened to me after installing ThinkOffice. There is a reset button just below the labe "Made in China" on the back of the unit. Hold that button in with your stylus.
Nov 18, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 error
Everytime I got that error, press soft reset on back and it should reboot normal
Oct 12, 2008 | Palm Tungsten E2 Handheld
IQue 3600 Fatal Alert
You'll have to do a hard reset. Push the reset button, then hold the power button until the Palm Power appear and then release the power button. Next it will ask if you want to erase the data. I hate to said this but select yes. No will not work. Then after the inital set up run a HotSync.
Jun 18, 2008 | Garmin iQue 3600 GPS Receiver
Note pad
Maybe some other program has modified the Notepad program. Back up all your files and do a hard reset. Still not work, call palm...
May 13, 2008 | Palm Zire 71 Handheld
Fatal Alert problem
We prayed and asked God to save the data even though we had to do a hard reset. Data was preserved entirely! For this we give thanks--and praise.
Rob Starner
Feb 19, 2008 | Palm Tungsten E2 Handheld
Open Questions:
HotSync Problem on Treo 90 When I press the HotSync on the Trio 90 cable (I do not use a cradle) in place of the moving red and blue arrows moving, the Microsoft Unplug or Eject Hardware icon appears in the lower right portion of the task bar. I assume this means that contact has been made between the Treo 90 and the PC. This icon remains until I receive the following message on the Treo 90: “HotSync Problem” “The connection between your handheld computer and the desktop could not be established. Please check your setup and try again. This problem began after I updated to WinDesktop_401_ENG_V, Treo90Updater11, and PMStdUpdate3171. I downloaded USBRegClean.exe and used it. Then I reinstalled WinDesktop_401_ENG_V and the problem continued. I emailed my log to Chapura Support. Unfortunately, this was done after I had uninstalled and reinstalled everything and the log did not show here a Synchronization had been established because after the reinstall, I have been unable to Synchronize. I checked the PalmOne knowledge base and did the following: I checked to make sure the cable from the HotSync was is securely attached to the USB port in the back of the PC and that the cable was securely in the Treo 90. I click on the HotSync manager, (Double arrow icon on the bottom right corner of computer screen), click on setup and then local tab and first set it to PC overwrites Handheld, this did not work, I then reset it to Synchronize, this did not work, I then reset it to Handheld overwrites P.C. This did not work. I also changed the speed settings to 9600. This did not work. I did a soft reset of the Treo 90. The reset took place, but the problem persisted. I did a hard reset, then uninstalled and reinstalled everything. However, when I try a HotSync, I keep getting the Microsoft unplug or eject hardware icon. I uninstalled all UBS ports. The problem continued. Chapura Support suggested using PalmOne’s HotSyncCheck which I interpreted to be the “USBRegClean.exe” and used it again and then reinstalled WinDesktop_401_ENG_V successfully. However, when I reinstalled Treo90Updater11, and PMStdUpdate3171, when I attempted a HotSync it failed and I continued to get the Microsoft Unplug or Eject Hardware icon. Is there a fix? Is it possible that the problem is physically located in the Treo 90? If so, where can I take it to be checked and serviced if necessary? Thank you for your attention to this problem
Feb 27, 2017 | Handspring Treo 90 Handheld
Handspring Treo 90 Handheld Logo
131 people viewed this question
Top Handspring Computers & Internet Experts
ray gallant
Are you a Handspring Computer and Internet Expert? Answer questions, earn points and help others
