Question about Canon PIXMA® MP530 All-In-One Printer
Cannot fax ... Memory in use 0%
Unable to fax. When document inserted for faxing the display says Mem in Use 0%. No memory light flashing. Menu button not responding. Cannot switch to Copy. All inks are full. Switched off and unpluged overnight but problem continues.
  • salesbj Nov 07, 2008
    Have been using the machine for about 15 months
  • salesbj Nov 10, 2008
    Problem sorted, at present anyway ..... switched off/unplugged machine overnight again but also removed telephone lead. Try your suggestion if it happens again.
  • 27 Answers
Hii..
how long you have been using this fax.
Posted on Nov 07, 2008
  • msaufie Nov 08, 2008
    hii...try this,
    take out all cartridge from you machine..leave about 30minute or 1 hour..turn on machine and than put in cartridge..if still the same problem some thing wrong with the logic board..
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
How can i print my faxes that are received in memory? My fax is flashing - Auto Print Off - Rec'd in Memory. How can i access my faxes from there?
Here are the instructions from the onscreen manual from Canon USA.:
Printing or Deleting a Document in Memory
1 Press the FAX button, then press the Menu button.
2 Press the l_mark.jpg or r_mark.jpg button to select MEMORY REFERENCE.
3 Press the OK button.
4 Press the l_mark.jpg or r_mark.jpg button to select PRINT DOCUMENT or DELETE DOCUMENT.
bullet_s.gif If you select PRINT DOCUMENT: (1) Press the OK button.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number by pressing the Numeric buttons.
If you are unsure of the transaction number, print the memory list. See Printing a List of Documents in Memory.
(3) Press the OK button.
(4) Press the l_mark_s.jpg button to select YES to print the first page only, or press the r_mark_s.jpg button to select NO to print all pages of the document.
I hope this answers your question.
Dec 18, 2009 | Canon PIXMA MX310 All-In-One Printer
MX310, says receiving fax but nothing comes out.
michael885 -
Your unit has a certain amount of memory designed to store faxes... if they are stored there, here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Aug 02, 2009 | Canon PIXMA MX310 All-In-One Printer
How do you check the memory when solid green light
svmtony --
Here are the instructions for at least printing what is in your memory, and how to delete the memory as well.
You can download the entire user manual (in PDF format) from the link below (the download is on the right-side of the page, about 1/3 of the way down the page):
Here are the instructions for retrieving the fax's from the memory:
Hope this helps!
-- RT
Jul 31, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 In use/memory light flashing, nothing in memory and unit not in use. Powered down and re powered still the same.
redtaildesig --
Have you tried to purge the memory? To delete the files in memory:
If you'd like to print from memory (I think you already know how,but just in case):
Hope this helps!
-- RT
Jul 30, 2009 | Canon PIXMA MX310 All-In-One Printer
Please assist me in printing a fax message that is stored in the memory of my Canon MX310.
Hi there
Before printing an actual fax, you may want to see a list of faxes stored in memory. To do this:
  1. Press the FAX button, then press the Menu button.
  2. Press the or button to select MEMORY REFERENCE.
  3. Press the OK button two times.
  4. The memory list is printed.
Note:
  • If there are no documents stored in memory, "NO DOC. IN MEMORY" is displayed, and the machine returns to the previous screen.
  • In step 2, you can also select PRNT REPORT/LIST (see Summary of Reports and Lists) and then MEMORY LIST to print the memory list.
  • If you have canceled receiving a fax in progress by pressing the Stop/Reset button, the fax may be printed after the memory list.
Now, when you're ready to print the specific fax you like, please do the following:
  3. Press the OK button.
  4. Press the or button to select PRINT DOCUMENT
  5. Press the OK button
  6. Press the left or right button to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number by pressing the Numeric buttons. If you are unsure of the transaction number, print the memory list. See Printing a List of Documents in Memory.
  7. Press the OK button
  8. Press the left button to select YES to print the first page only, or press the right button to select NO to print all pages of the document.
  9. Press the OK button.
I hope I have been of some help.
Best regards
nLinked
Jul 03, 2009 | Computers & Internet
Looks like I have an incoming fax: screen reads, "received in mem
You have the fax setting to use memory or no paper loaded.
Go to the fax menu and change it to print.
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Brother fax 560
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Apr 15, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Canon MP530 - Fax Memory is Full... How do I clear?
Check your ink cartridges and fill any that may be low. I got that error because one of the cartridges (magenta) needed to be refilled. The printer was storing failure reports in its memory until they could be printed out, leaving no room to fax new documents. As soon as the ink cartridge was replaced, the reports printed and freed up the memory to send out faxes.
Dec 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Memory full display when trying ty fax
Thks for the above info. Went to my 530 to fix same problem and didn"t work. Mem in use light kept flashing. Re-traced phone line and outside line and found they were plugged into wrong jack. Moved the phone to the phone plug and outside line to outside line, and problem gone. This worked for me but there may be other causes that will make this happen
regards
oldcoot
Oct 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA® MP530 All-In-One Printer Logo
126 people viewed this question
old marine
old marine
