What componenets need to be replaced, and where are they located? Thanks!
Like a lot of error codes, this one is general in nature "deflection circuit problem" which usually means in the Horizontal output circuit but can mislead you.
Someone needs to open and check voltages there, inspect for any signs of Glycol, and check for shorts to ground in that area of the set= it can be anything from a 1 dollar part to a major part.
The service manual should be available online for free and if tech savy let me know.
SOURCE: Mitsubishi WS 65511 convergence
Go on line and get an original Sanyo STK 393-110. Next, restore the blue centering rings back to where they were before you moved them. Look at the paint marks on the rings for reference if you are not sure. Replace the IC and check the resistors nearby for signs of overheating and proper value. Also check the fuses that supply the 24v to the IC. The service manual will show you the fuse location and give you the resistor values in the blue horizontal and vertical circuit. Checklist: You need a de-soldering tool or a good quality Dry Wick. Have a small tube of heat sink compound to liberally apply to the new chip. The hardest part will be lining up the double rowed pins on the chip and getting them to seat at the same time. Next, go to the convergence menu and follow the instructions. Good luck! PS you might want to remove the chassis from the cabinet to make it easier. Be careful to unplug the speaker plug and untwist the wire ties from the cabinet. Be very careful, this job is not designed for beginners.
SOURCE: MITSUBISHI 65" RAER PROJECTION TV MODEL-WS 65511
Try to press both the menu button and the input/device button on the set both in together and hold in for 6 seconds to see if the led will blink a two digit blink code, then let me know the two didgit code, and I will try to assist you. Please respond to this same post when replying.
SOURCE: No Picture after Wii Play: 65'' Mitsubishi HDTV 1080 (WS-65511)
mmm try this.... do u guys have the yellow white red cables hooked up to the front of the tv from the wii console? try loosening them up. worked for me. let's see how long it lasts .... !!!!
SOURCE: ws-6580 error code 23
CODE / INDICATES
12 / No error has occured
21 / X-Ray Protect Shutdown
22 / Short Protect Shutdown
23 / Horizontal Deflection failure
24 / Vertical Deflection failure
SOURCE: WS-65511 turn itself off after turned on a few
Your STK convergence ic's need replaced.
Testimonial: "TV is working again after I replaced the STK convergence IC and a pico fuse."
