On my bass amp head, the fan is very noisey - Audio Players & Recorders
  • 1,512 Answers
Hi
There is not much you can do to fix a noisy amp. If it has a buildup of dust and gunk on it, then cleaning it with a blowout of compressed air can help, but the best solution is to replace the fan. If you can give me some details of the fan, I can steer you to a place to get a replacement. Happy to help answer questions you may have about it.
regards
robotek
Posted on Nov 08, 2008
I have behringer bx4500 bass head that hums and the fan on the back doesnt come on. What causes this to happen?
THere can be various causes, none of which will be user serviceable. Contact Behringer for the nearest service center. Here is the link-
Behringer Bugera Portal Starin Distributing
Sep 25, 2016 | Behringer 450 Watt Bass Amp Head BX4500H
Trying to connect peavey tour 700 to a trace elliot 1518 bass enclosure. Plug the enclosure to the back of the amp. Then plugged my bass into the high gain. Turned it on and nothing happens.
Check continuity on all cables, try a different cabinet with the head and a different head with the cabinet and the bass with a different rig to see which part of the chain isn't working, make sure the volume controls are turned up on both the amp and bass. Once the problem is narrowed down it will be easier to advise you.
Oct 12, 2014 | Music
How to adjust Dg11100 car amp
If your head unit has an amp gain, turn it up as high as it will go. If it is hooked up to subs, the head unit will say subwoofer output in the menu. Then take a small screwdriver and turn the amp gain on the side of your amp counterclockwise to zero. Turn your freq. up to about a third. Crank your system up, with a song with good bass, and slowly turn your gain up till the bass from the subs sound distorted, and back it back down. If the bass is drowning out the other speakers in your car, then turn the gain down some more. I find it works best if you have your trebble up high, your mid range at a little less than half. And your bass at zero or one. Your amp is cranking up the bass, so let your other speakers handle the rest. This allows it to sound clearly at higher volumes.
Jan 02, 2013 | Cars & Trucks
I need Schematica from the Ashdown little giant. I expect that the fan is not properly connected.
Don't have the schematics for this one... have for a 500 watt one... HOWEVER from that one the schematic shows that the fan is "throttled" by a negative temp resistor which should run the fan when the temp goes up where the sensor is located. The fan MAY not run at all until the temp reaches a certain point.
Aug 26, 2011 | Ashdown New Ashdown Little Giant 350w Mini...
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have...
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
May 06, 2011 | Kustom Deep End 200HD 200 Watt Bass Amp...
This bass squels if you have a bass head and cabinet. i had a 100W amp and it played fine then upgraded to a head/cab. tryed playing it with loud volume, squels. anyway to fix this?
Turn down the treble gain and mid gain... you don't need it for a bass. Prevent the guitar from "hearing" the output of the amp directly. The guitar strings make a good microphone.
Feb 27, 2011 | Epiphone EBO Electric Bass Guitar...
Hp dv6810 keeps overheating and turning off fan is ver noisey
Make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Oct 13, 2010 | Computers & Internet
Cooling fan motor grinds and very noisey would like to replace cooling fan,where ca i obtain oem part for this mg250dfx
The fan will have a manufacturer's part and name on it.
Shop Digikey.com or Mouser.com for identical device.
Note that SOME amps have the fan throttled depending on temp and these fans get noisey when throttled down.
Not sure about your Marshall on. The usual fan failure is bearings get dry and coke the lubricant.
Feb 24, 2010 | Marshall Amplification Marshall MG250DFX...
Alpine 9845 cde head unit car stereo i Cannot figure out how to access the Fader not the balance,altho i havent seen that function either. ive been to the alpine site and they dont even mention it. im sure...
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS → TREBLE → SUBWOOFER* → BALANCE → FADER
→ DEFEAT → VOLUME → BASS
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
Feb 11, 2010 | Alpine CDE-9845 CD Player
More bass
Run one set of RCA lines from head unit to amps if you only have one set of pre-outs on the head unit, then at the amps, use an electronic crossover to split between the two amps, and this will also allow you to control what frequencies go to which amps/speakers. You should use one amp for the speakers and the higher power amp for the subwoofer. You should not try to connect both to the subwoofer. Use 4gauge cables if possible. If you have more questions, just ask.
Oct 29, 2007 | Pioneer GM-7200M Car Audio Amplifier
71 people viewed this question
 Grubhead
Grubhead
