Question about Holmes Products HOLMES COMPACT OIL FILLED HEATER - POH2520-U
Heater will not operate!
My Holmes Oil Filled Heater #2505 worked fine yesterday, but today, when I turned it on, there was no power. I moved it to different outlets, but it still does not work! Please help - it was purchased in 11/05. Carol Bryans
  • 625 Answers
Did you take it apart to see if the switch is good or the thermostat was functioning?  without looking inside, other than saying it don't work, isn't going to solve anything.
Posted on Oct 15, 2007
Won't Turn On
My suggestion is that it is either the power control switch or failure of the heating element. Sudden failure can occur even in something brand new.
Dec 10, 2013 | DeLonghi TRD0715T Oil Filled Radiator...
My Comfort Zone Oil filled CZ7007J Radiator is not heating, it was working just fine when I turned it off, but when I turned it back on, no lights, no heat, like it's getting no power. Bought it
doubt there is any warranty being made in 2010 but they do have a heating element very similar to an electric water heater .I know of no repair shops that work on them.nor where you might find an element . SORRY Personally I found these oil filed heaters cost more to operate than the ceramic. types
Dec 30, 2017 | Comfort Zone CZ7007 Oil Filled Electric...
I have a Holmes accutemp model HOH2520 TG-U. The heater operates for about 10-15 minutes and then the digital readout starts fluttering and it stops heating. The next day it does the same thing. Nice...
Hello- These heaters have been recalled.The Holmes heater company will mail you a new free heater, if u mail them back your power cord. Please check the recall website. Julie :)
Mar 02, 2011 | Holmes Products HOH2501 Oil Filled...
Will not turn on. Unit has been working great until tonight. Was on but now off and will not come on. Unpluged it for an hour but still not working.
This same thing happened to me, and yesterday as well no less. I've had mine for a 3-4 years. I think It had run out of oil, which is weird because I've had a Holmes heater for nearly 10 years and it still has plenty of oil left. If you shake it, can you hear the oil? I went and got another from Target last night (it was the coldest night of the year) and can hear the oil swishing around in it as I set it up. Hope it last longer than another 3-4 years or my next one will be a Holmes.
Jan 22, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Heater is not coming on
That makes sense, you were pulling well over over 20 amps. It doesn't make sense but it appears the heater failed. I would assume the heater has an electronic control that got zapped by the surge generated by the vacuum cleaner when the breaker tripped. If it is not an expensive heater just get a replacement. Unless you are experienced in repairing these things it is much safer just to replace it.
Good Luck,
Gilshultz
Dec 01, 2009 | Holmes Products HOH2501 Oil Filled...
Control panel blinking
my heater did the same, very frustrating. i have solved this problem.  i took off the plastic cover to expose the electronic circuit board and noticed that there was a white residue on the board. I wiped this clean with rubbing alcohol and put everything back. as of 3 weeks ago i have used the heater frequently as normal and not had any problems. chazdee
Dec 06, 2008 | Holmes Products HOH2520-U Heater
My oil-filled Holmes heater HOH2520U will not heat now. it was working for a while the shut its self off and now the control panel is constantly blinking unless it is set at the room temp. HELP PLEASE
I had the same problem. this is what i did. unplug the heater. removed the plastic panel to expose the control panel where the blinking light is.  Removed all the dust and cobweb build up, then using rubbing alcohol, wiped the white residue that was on the green circuit board. I did this 10 days ago and the heater has been working fine since then. chaz
Not heating
Sounds like either the thermostat or the element. If you hear a clicking when you rotate the thermostat you can assume that it is working. My advise is to replacethe heater. The element is sealed inside the oil chamber and the thermostat will cost almost as much as a new heater, sorry.
Dec 05, 2007 | Holmes Products POH2501 Oil Filled...
Heating & Cooling Logo
484 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
