Question about Navman GPS
I have a navman Fish 4600 sounder first problem the speed fluctuates while going at a constant speed.Second when you turn the unit on it takes quiet a while to to acuratly see the bottom. Any help would be great. Cheers Pete
5 Suggested Answers
SOURCE: problem with navman 4150 fish finder
I installed my Navman 4150 depth finder along with the Navman GPS unit when I purchased my Bayliner Trophy 20Ft. Offshore model. Everything was ok for one year and it has been downhill since then. Losing signal, unbelievable high depth ranges, blank periods, etc.. I now can't even get a reading tieded up at the dock. I am now giving up and shoping for a quality unit.. Cape Disappointment.........
Posted on Jul 21, 2009
  • 111 Answers
SOURCE: i can never read the fish on the screen
perhaps someone has messed with your sounder settings. You may want to factory reset the sounder from within one of the menus in your navnet. Also you may have a transducer going bad. Did you hit anything with it or run aground once? Maybe someone painted over the face of the transducer with bottom paint. There's alot of things that can cause this to happen. It would be best to have the sounder checked out before you do anything to the ducer. Remove your navnet and sounder and take it to a dealer to test on the bench. If you're in the maryland area, Mid-shore Electronics and handle this for you. Even if you're not, you can send the units to them.
Posted on Feb 01, 2010
ZJLimited
  • 17970 Answers
SOURCE: Navman fish 4500. Won't
Keep in mind that something wire could be loss in ths installation or ground there.
1. The fishfinder won’t turn on:
a) The FISH 4500/4600 is designed to operate on a 12/24 volt battery system, where the voltage may vary from 10 to 35 volts. If an excessive voltage is supplied, a fuse will be tripped, turning the display unit off. Check the fuse.
b) Check that the power cable connector at the back of the display unit is securely plugged in and the collar is locked in place. The collar must be secure for watertight connection.
c) Measure the battery voltage while the battery is under load - turn on some lights, radio or other electrical equipment connected to the battery. If the voltage is less than 10 volts:
- the battery terminals or wiring on the terminals may be corroded.
- the battery may not be charging correctly or may need replacing.
d) Inspect the power cable from end to end for damage such as cuts, breaks, squashed or trapped sections.
e) Ensure that the red wire is connected to the positive battery terminal and the black wire to the negative battery terminal. If wired for the Auto Power option, ensure the yellow wire is connected to the ignition circuit. Also check the boat’s main switch circuit (see section 6-5 Wiring options).
f) Check for corrosion on the power cable connector and clean or replace if required.
g) Check fuses that are placed in line with the power cable. A fuse can be blown despite appearing to be good or the fuse may be corroded. Test the fuse or replace it with a fuse known to be good.
2. The fishfinder operates erratically:
a) Check that the transducer does not have debris (e.g. weed, plastic bag) caught around it.
b) The transducer may have been damaged during launching, running aground or while underway with debris etc. If the transducer has been impacted, it may have been kicked up on the bracket. If it is not physically damaged, reset the transducer back to its original position. (see the Transom Transducer Installation Guide.)
c) When the transducer is less that 2 ft. (0.6 m) from the bottom, the depth readings may become inconsistent and erratic.
d) Manual Gain may be set too low, which may cause weak bottom echo or no fish signals. If in Manual Gain, try increasing the Gain.
e) Ensure the back of the bottom surface of the transducer is slightly lower than the front and the front is as deep in the water as possible in order to minimize the generation of bubbles through cavitation. (see the Transom Transducers Installation Guide.)
f) Check the transducer and power cable connectors at the back of the display unit are securely plugged in and the collars are locked in place. The collars must be secure for watertight connection.
g) Inspect the power cable from end to end for damage such as cuts, breaks, squashed or trapped sections.
h) Ensure there is not another fishfinder or depth sounder turned on, which may interfere with this fishfinder.
i) Electrical noise from the boat’s engine or an accessory may be interfering with the transducer(s) and/or the Navman fishfinder.
More information can be found on site: www.navman.com
Hope helps.
Posted on Aug 25, 2010
SOURCE: Navman Tracker 5505, number 0603A30035604.
1.The TRACKER is designed to operate on a 12/24 volt battery system, where the voltage may vary from 10.5 to 32 volts. If an excessive voltage is supplied, a fuse will be tripped, turning the display unit off. Check the fuse.
2. Check that the power cable connector at the back of the display unit is securely plugged in and the collar is locked in place. The collar must be secure for watertight connection.
3. Measure the battery voltage while the battery is under load - turn on some lights, radio or other electrical equipment connected to the battery. If the voltage is less than 10 volts:
4. Inspect the power cable from end to end for damage such as cuts, breaks, squashed or trapped sections.
5. Ensure that the red wire is connected to the positive battery terminal and the black wire to the negative battery terminal. If wired for the Auto Power option, ensure the yellow wire is connected to the ignition circuit. Also check the boat's main switch circuit
6.Check for corrosion on the power cable connector and clean or replace if required.
7. Check fuses that are placed in line with the power cable. A fuse can be blown despite appearing to be good or the fuse may be corroded. Test the fuse or replace it with a fuse known to be good.
Posted on Jan 29, 2011
  • 76 Answers
SOURCE: how to get the fish
ok mate hear you go here is the manual just click here http://www.furunousa.com/ProductDocuments/FCV585%20FCV620%20Operator's%20Manual%20e.pdf
go to page 21. you will need abobe reader but most people have that if you dont just go to adobe.com and download it its free. ok hope that helps. please leave a vote.
Posted on Mar 11, 2011
Hi! Engine thiefs cutted off the cable of transducer of Navman 4430. Any idea where to get a new transducer with cable as a spare part?? Pxi
Pekka, Transducer and cable at links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
FISH 4430 Options Navman Marine
Navman Transducer Accessories eBay
Amazon ca transducer
Apr 20, 2016 | Navman GPS
Unit and /or screen will not stay on
bad power cord conection or bad plug in.try in differant plug in
Jul 07, 2015 | Garmin GPSMAP 178C Sounder TrueVue...
When i turn my navman icn310,its just says waitin for gps,wot does this mean
It means it's searching for GPS birds. The initial process may take up to 15 minutes for the unit to locate enough birds to locate itself. after it's located the birds and itself, subsequent power on sequences should be shorter in locating the birds.
Mar 03, 2010 | Navman iCN 330 GPS Receiver
I can never read the fish on the screen of my sounder whether is in auto or manual mode (yes we are catching fish)
Dec 31, 2009 | Furuno NavNet vx2 GP1720C GPS Receiver
Problem with navman 4150 fish finder
Jan 07, 2009 | Navman Fish 4150sx GPS Receiver
Navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
Sep 20, 2008 | Navman F4100SX Fishfinder - W/ Transom...
Navman 4150 sx
Go to the Website of Pertec.co.za and download the manual for the 4150 and 4150sx
Hope this will help
Regards
Albie Rossouw
albieros@mweb.co.za
Jul 20, 2008 | Navman Fish 4150sx GPS Receiver
Navman 4150sx
This is my e-mail adress skukuma@globesky.com send me your adres and I will send you the manuel
Jun 08, 2008 | Navman Fish 4150sx GPS Receiver
Log and trip function not registering
It is unlikely the problem is in the A65 screen.....most likely it is an issue with the paddlewheel itself, its circuit in the depth/speed transducer, or least likely, in the DSM25 sounder module.
Both the log and the trip functiions are read from the paddle-wheel sensor of the connected DSM25 sounder module and transducer.
1. Make sure you have a DSM25 sounder module and transducer with a paddle wheel (the A65 is available without the DSM25 option.)
Double check the connections between the DSM25 and the A65, as well as the transducer connection to the A65. There is an indicator light on the DSM25 to confirm it is on.
2. Make sure the paddle wheel turns freely. They tend to get fouled easily with debris and growth.
3. Make sure the A65 is giving to a reading for SPEED when underway or when having a buddy spin the paddlewheel by hand. Do not confuse SPEED with SOG. SPEED is from the paddlewheel.....SOG (Speed over ground) comes from your GPS sensor and is not used by A65 for log or trip purposes.
If you get npo speed reading at all the paddle wheel may be defective or the depth/speed transducer may be defective. See your dealer about a replacement.
Nov 06, 2007 | Raymarine A65 Combo GPS...
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
GPS Logo
143 people viewed this question
Top Navman GPS Experts
Iron
Iron
Are you a Navman GPS Expert? Answer questions, earn points and help others
