Question about Zoom Audio Players & Recorders
Zoom H4: 1. the USB connection no longer works; computer does not detect the recorder. 2. the 1st input is too loud and distorted, so I cannot record through both simultaneously, as input one drowns out input 2, despite any balance adjustments I make to the volume of either input. 3. now input 2 is developing distortion... is there any way to fix this or is it just stuffed?
    Problem Solver:
  • 8 Answers
If you are using a Mac and have Leopard (sys 10.5) You need to upgrade firmware on the H4 from Zoom website
http://www.zoom.co.jp/english/download/software/h4.php
You will need an external SD card reader.
Good Luck
Posted on May 24, 2009
Recording from DMX 6fire distorted
try isolating the usb that you are using by removing all unnecessary items like extra headphones, cellphones, speakers, battery backup usb connection, you name it. More than likely the static is from that. or try a different usb port if you have removed these items
hope this helps
Feb 19, 2014 | TerraTec Electronic Terratec DMX 6fire...
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
Zoom h1 handy recorder
Download the H1 driver for windows & try different usb cable........
Mar 09, 2017 | Music
My new Zoom H1 will not connect to computer through USB.
Hi did you get it sorted,got the same problem,dont want to have to send it back only got it today, saving for ages,can you help
Oct 28, 2012 | Samson Technology Zoom H1 Recording Bundle...
My Zoom H2 recorder is not recognized by my new computer with Windows 7. What can I do to solve this?
No solution, just a workaround. I have used the H2 with firmware 1.90 successfully with Windows 7, but lately the H2 is not recognized anymore. Built-in obsolescence maybe?
Anyway, I just take out the card and put it in a card reader. It is faster also. Card readers are cheap.
Sep 07, 2011 | Zoom H2 Digital Voice Recorder
I have connected the samson mic to my computer. input not detecte
A condenser mic. requires "phantom power" usually supplied by a mixing desk. Without this, there will be no output signal from the mic.
Jan 12, 2010 | Samson C01U - USB Studio Condenser...
Distorted recording of Record Albums
Are you talking about trying to transfer them to computer?
If you are what might be happening is that the signal from the deck to the computer is too strong. The way to cure this is by reducing the signal on the control panel of your computer. For instance I use SoundMAX and it as record input slider, which can be reduced to cut the signal from outside audio sources. I also switch off the graphic as adding bass etc to a recording can cause problems.
Nov 26, 2009 | Electronics - Others
Trouble recording records
When recording from a phonograph, I use the following items.
Depending on the phonograph whether or not it's MC or MM makes a difference in sound although most can't tell the difference. Also, you need to know if your phonograph requires a pre-pre amp or if that pre-pre amp is built in and the line coming out is at line level. The Rolls item is a pre-pre amp unit which takes to older phonographs signal level to that of input levels which allow the phonograph to be connected to any aux line in.
On the back of the computer, you can plug the RCA jacks from the phonograph into the adapter and directly into your computer via the MIC (usually pink) input. Most of the time this is sufficient. If the volume is too loud, or sounds horrible, chances are you have a pre-pre amp and you then plug it into the line in (usually blue)
First I would connect the RCA's from the phonograph to the adapter and plug it into the mic and see how the sound is.
Keep in mind that you do not use the ROLLs unit when connecting this way. If it's too loud or distorted, plug it into the line in.
For recording, you can download Audacity which is free and a wonderful editing program.
Nov 26, 2008 | Televison & Video
Distortion with Zoom H4 as Audio I/O to computer
try using the power pack instead of batteries. Be sure to remove the batteries before using power pack, you can wreck the machine if you do not remove batteries. NEVER use the H4 on power pack while there is batteries inside.
Mar 31, 2008 | Zoom H4 Handy Recorder
DISTORTION
1) if you are using the PC sound card to record this is where your hiss is coming from. you need to get a recording card that has low noise or some other recording USB input device to get CD quality recordings
OR
2) if you have to use your PC sound card check your PC volume level for line in, don't let it get high or it will distort. you will have to experiment with the MD4 levels and PC sound card level to find a good middle ground with low hiss and no distortion
and a singer that sings away from the mic to reduce distortion.
hope this helps
thanks for your rating
Jan 09, 2008 | Shure SM87 Professional Microphone
67 people viewed this question
Top Zoom Audio Players & Recorders Experts
Jaysan Lunt
Level 1 Expert
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
