Question about LG WD-12126RD Front Load Washer / Dryer
Won't unlock The handle on the door doesn't respond to unlock the door. If feels as if the trigger on the mechanism is broken and won't trigger the unlock. How else can I open the door or remove the door?
I've had a similar issue occasionally;
First, try turning it off and on again.
Then push the door closed with your knee as you pull the release handle.
My door seems to close tighter at the bottom than the top, so I have to push the bottom of the door in fully sometimes to get it to open. I guess some kind of sensor is getting tripped, and keeping the door locked..
I hope this helps!
Will
Posted on Jan 18, 2009
I have a 1999 kia sportage my driver door is closed an it isn't locked but it will not open for the outside handle or the inside handle what do i do to get it to open can't take panel off
If it's not locked but the handles aren't responding (they feel like they aren't really pulling on anything, no resistance) and the interior lights don't turn on when you pull the handles, you may have no choice but to get into that door panel. It's possible the door opening mechanism attached to the handles has broken, and should be looked at.
Aug 04, 2015 | Kia Cars & Trucks
2006 Chev Impala - back driverside door won't open from inside or out.
take the panel off the other side door and have a look and compair the two, though there is a small part between the two mechanisms that maybe missing
Jun 11, 2012 | 2006 Chevrolet Impala
Door won't open
You must have popped the door rod off.
Mar 03, 2018 | 1996 Chevrolet Suburban
Someone tried to break into my 07 chevy tahoe ltz they ended up breaking the rt rear door handle off ive got the new handle and already have the door panel off and the bolts out ready to replace it but...
{: ) Yes there is a rod. Check if it could have fallen somewhere inside the door. I have for you a diagram, although this is for the driver door, the configuration is much similar. The rear door uses a shorter rod and doesn't have much bends compared to the front doors. If the handle you bought doesn't come with this rod, so is the doorlatch. So the rod will come separate.
Check also from the picture below, and inspect the orange clip for damage. Since it was forcefully opened, it's possible the clip won't grip properly on the threaded edge of the rod.
Jul 21, 2011 | 2007 Chevrolet Tahoe
Rear door will not open on my 2007 Ford Fusion. It won't open from the inside or the outside. I removed the interior door panel and can look inside the door. I can see the mechanism for the outside door...
use the fob and keep clicking unlock/lock button see if everything is moving.then try banging outside of the door about 6 inches from door handle while pressing unlock.has worked on some other cars like vw audi and vauxhall
Dec 30, 2009 | 2007 Ford Fusion I4 SEL Sedan
Driverside inside door won,t open the dr or even unlock the drs handle is pulled to release?
more likely the door handle mechanism is either broken or came undone, the only way to get to it and see what broken or came off is to remove the door cover panel, its not easy job and its time consuming if not mechanical incline although it something fairly simple to fix and repair. you may just have to replace inner door handle if it broken off from the linkage.
Oct 11, 2009 | 1998 Jaguar XK8
Broken (or stuck?) driver's side door mechanism
Just go to a junk yard and pull them off a junker and put them on yours. Simple fix with a screwdriver. Most Toyota stuff has already been shipped out to Japan so you may have to go to a dealership for them. I can understand what your saying friend about cash limitations, if someone told me to pay attention I'd have to take out a loan. You'll work it out somehow. You may have to just hook a wire to the handle mounts to pull them unlatched. As for the one not unlocking, pull the inside panel off and unhook the lock and unlock it. Luck toya Bro.
Jul 07, 2017 | 1984 Toyota Tercel
LG 1480fhd
Try first to unplug the power cable and see if it allow you to open the door. In case it will not help, you have to raise the top of the washer to get to the switch and release it manually (The switch is inside the washing machine main housing near the door frame). Good luck
Sep 03, 2007 | LG WM-1480FHD Front Load Washer
LG WD-12126RD Front Load Washer / Dryer Logo
423 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
