Question about Xerox WorkCentre M15i Laser Printer
After upgrate firmware problem in receiving fax
I have upgraded the firmware version to 1.11 from the xerox website. I can still send faxes but the problem is receiving them, it stores them in the memory and i can't print them out. It shows secure fax on the display but when i go to the secure fax option on the menu i cannot disable it (second line is blank), it just show secure fax on the display and no options when i press the left or right buttons.
Xerox company is not responding.
Help! to downgrade the firmware.
    President:
  • 2,072 Answers
You most likely just have to reinstall it. Something in the upload to the machine just didnt go right. I have had to do those firmwarew upgrades a couple of times to make it work.
But, before you do that try this. This may really be what you have to do.
  1. Press the [Menu / Exit] button on the Control Panel. 'System Data' will be displayed on the Display Screen.
  2. Press the [Left] or [Right] arrow button until 'Memory Clear' is displayed.
  3. Press the [Enter] button.
  4. Press the [Left] or [Right] arrow button to select one of the following items to be cleared from memory:
    • System ID: Clears the fax number and name from the machine’s memory.
    • System Data: Restores all options that can be modified to the factory default.
    • PhoneBK / Memory: Clears the speed dial or group dial numbers stored in the machine's memory. In addition, all scheduled job operations that have been reserved are canceled.
    • TX-RX Journal: Clears all records of fax transmissions and receptions.
      NOTE: To exit without clearing the item, press the [Menu / Exit] button.
  5. Press the [Enter] button.
  6. If necessary, repeat steps 4 and 5 to clear another item from memory.
  7. Press the [Stop] button to return to the Standby mode.
Posted on Nov 07, 2008
Communication error
There is a common issue with a firmware problem that caused this to occur when receiving faxes. Try upgrade to the latest firmware that can be found at www.xerox.com under drivers.
Jan 15, 2016 | Xerox WorkCentre M20i All-In-One Laser...
We have a M2727 Laserjet Printer/Fax . We can print, and we can receive fax, but our problem is sending a FAX.. Keeps giving us an error code of 49. Please advise Thank-You, Marla
I found this on the HP website:
HP LaserJet M2727 Multifunction Printer Series - 49 Error Message Is Displayed While Faxing ISSUE: The printer control panel will be displaying 49 service error while sending faxes. The receiving fax will be lost, and the printer will display the same error even after reboot. SOLUTION: Performing a factory reset and a firmware upgrade is the only solution for this issue. Step 1: Performing a factory reset Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number. CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. Perform the following steps to restore the factory-set defaults: 1. On the product control panel, press Setup . 2. Use the arrow buttons to select Service , and then press OK . 3. Use the arrow buttons to select Restore defaults , and then press OK . The product automatically restarts. Step 2: Firmware upgrade After coming to ready, upgrade the printer firmware from the HP website. The issue can be fixed with any of the firmware upgrade available now. Firmware version 20080505 and higher versions have the fix. You can download firmware version 20080612 from the HP LaserJet M2727 Firmware Update 20080612 webpage. Click here to go to the HP LaserJet M2727 Firmware Update 20080612 webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-3&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=4&idx=3) . The preceding steps will resolve the issue.
Mar 07, 2011 | HP Office Equipment & Supplies
Samsung sf-650 intermittently sends a blank page
Print configuration report "Menu>Reports>Configuration/System Data"
Check the firmware version. 1.07 or lower is likely to have this problem
Upgrading the firmware is quite simple.
Get the update from samsung website Samsung.com>Support>Search Box "SF-650">on product support page find tab "firmware" and download upgrade file.
If you feel competent to do the upgrade (read the instructions in the txt file twice) do it.
Be aware that the upgrade will likely want to do a memory clear once it is complete so you will loose address book etc. Also do not power off unit during upgrade or you will damage the firmware and possibly make the unit unusable.
Hope this fixes the issue.
Feb 21, 2011 | Samsung SF650 Plain Paper Laser Fax
RECEIVES FAXES OK, BUT ONLY SENDS BLANK SHEET
Feb 16, 2011 | Samsung SF650 Plain Paper Laser Fax
Phaser 8560MFP - Several Small Problems
Very much sounds like corrputed software. You can go to the Xerox.com site and download the newest software version .
Go to the xerox.com site, click on drivers and downloads and type in your machine model number. And it will take you there.
Dec 22, 2009 | Xerox Phaser 8560MFP Laser Printer
Cannot send or receive faxes
This problem might be the moden board, or main board, or both.
Oct 13, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Can receive a fax, but cannot send fax.
I was told by Xerox support tech that he thought it was the fact that we do not have a dedicated analog phone line, but the fact remains we can receive faxes but cannot send them. The only fax that will send is directly to Xerox support.???. The machine was working fine, faxing (sending and receiving), until about a week or so ago, when we had a repairman here on the printer. He told me to report the problem to our telephone repair service. He is coming out today! I'll let you know.
Feb 19, 2009 | Xerox Phaser 6115MFP/N Laser Printer
Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox WorkCentre M15i Laser Printer Logo
173 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
