Question about HP Photosmart D5160 InkJet Printer
Speed of quality don't work.
HP Photosmart D5160...Fast Normal & Fast Draft not work like usually...it move slow...how can i make them work fine..would you give me a solution..? thx...
Just arrange the setting in the property menu...
Posted on Nov 08, 2008
The printer takes a long time to print.
Buy a faster printer.
And, no, I'm not being a smart-aleck
HP rates this printer at up to 32 pages per minute -- in fast draft mode black ink only... But even their ratings show it takes over a minute per page when doing quality printing in color.
And those speed ratings are all "after first page" -- ALL printers take longer for the first page due to the time it takes for the computer to set up the page and process the information.
As the specs suggest, you can get faster printing in black-only instead of color and by choosing fast draft mode instead of quality or normal mode.
There is very little that could be wrong with the printer that would make it print slower than usual -- generally any problem would make it not print at all or cause it to print incorrectly. Generally speaking whatever speed you see is simply the speed of the printer itself based on the settings you have selected, the software you are using, and the speed of your computer.
You can refer to the information on the HP website. It is just possible that replacing the printer driver MIGHT help but other than that there simply isn't much you can do about the speed of this (or any) printer unless you want to choose a lower quality print setting.
HP Photosmart C5250 All in One Printer Product Information
Mar 08, 2014 | HEWLETT-PACKARD photosmart C5250...
I have a 2410 HP printer and it prints very very very slow. Can you help me? Email address pretty111comcast.net
I have the exact same model of printer, I find that it prints faster if you go into printing preferences and change the print quality to fast draft or fast normal. You can also set the printer directly by pressingcopy twice then press3 for copy quality, then select 3 for fast.
Doing both should produce faster printing for your documents. (NOTE : This will not suggested if you are printiing items that need to have crisp clean printing as the faster it prints the less detailed the printing is.)
Jul 22, 2012 | HP PSC 2410 All-In-One InkJet Printer
My printer is very slow it takes aprox 2 min to print color and 1 1/2 for b&w
Try changing the quality settings to the lowest setting (usually called draft or economy). If that doesn't speed up the printing the issue is most likely with your computer, not the printer.
Mar 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
Want to speed it up
There are several things that may cause you printer to be slower than advertised. Click on control panel and then click on printers and right click on your 5550 and you'll see a drop down menu. Then select printer preferences. You'll see a screen with several tabs. go to paper/quality and click on it and make sure you have 'default printer settings' in the little window near the top and then look at Print Quality near the lower left--make sure this is set on Normal, fast Normal or draft. This should help speed the printer output. Also, printing full pages of small print and color will slow things down quite a bit.
hope this helps.
Jul 31, 2010 | HP DeskJet 5550 InkJet Printer
Not printing to fast draft
Make "fast draft" your default setting, otherwise, whenever you open a new document, it will print it in "normal mode".
Mar 09, 2010 | HP Photosmart 7450 InkJet Printer
My printer is hp 2418 it is given print is very slow . so what to do
Adjust the Quality Settings for your printer.
Reduce the quality.
If it's on Best/Maximum Quality, Then change it to Normal or Draft.
That will speed it up, although it will accordingly reduce print quality, as well as amount of ink used per page.
Mar 08, 2010 | HP Photosmart C6280 Printer
It really prints so slow
Try setting the printing properties to fast draft or draft. It provides a average quality document faster using less ink.
To do this, go to Start->Control Panel and then Printers. Right click on your printer and choose printing preferences. Find the setting for the quality and select Draft or Fast Draft if it is available.
Please note that this printer has a rate of 5.36 pages per minute, so even with the draft you will not see much difference.
Regards,
nicolasiac
Feb 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
Prints slow
Check to see what quality you are printing in, all printers print slower in normal mode compared to fast or draft mode. When you go to print click on property and change the quality. This is normally a temporary fix to keep the settings you need to do the same thing inside the printers folder.
Mar 15, 2009 | HP DeskJet 648c InkJet Printer
Hp photo printer 7660 paper size error
it is a correct driver of your printer? if so try to reinstall also your OS maybe is attack by some worms.
Jan 07, 2009 | HP PhotoSmart 7660 InkJet Printer
Prints "fast draft" only
hi to all ... my printer did not work good when I give it order to print the first paper let it with out pint but it print after that a bout 5 sheet than stop .notis I order one copy.....what should I do
Dec 18, 2008 | HP Photosmart 7450 InkJet Printer
HP Photosmart D5160 InkJet Printer Logo
79 people viewed this question
Seeker5211
Seeker5211
