The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
I upgraded mine to an Intel Core 2 Duo T5600 (Stepping SL9U3), and it's working fine. It's faster, dual core, 64 bit and supports VT, I have more details on my website here: https://www.sambartle.co.uk/technology/asus-x50r/
Deffinately This Mother Board supports Dual core 2ghz-2.8Ghz And Pentium D 3GhzProcessors.You can Upgrade your PC.
P5V800MX motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date. Enjoy the extraordinary CPU power from the latest dual-core CPU.
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
I am taking it that since you had a dual core 4400+, your using a AM2 motherboard..
Bout the best you could do with that board is find another dual core, perhaps an AMD FX70 or FX62. Unfortunately AMD is not keeping up with intel , they sorta failed with the quad core.
If your smart, you'll save till you get enough to jump a couple levels and replace the ram, cpu and motherboard.
sorry no prescott support only single core 3.0 ghz at new egg around 80 bucks but if you are looking to upgrade you can go a long way for cheap dmh1167 @ hotmail . com please let me know if you need help.
Highest model cpu your board can support is the AMD Athlon XP model 3200. This is not a dual core cpu. You would need to upgrade to a newer motherboard in order to use a dual or quad core cpu. Hope this helps.
Do you know what the CPU socket is or chipset? If the CPU socket is a 478 then no dual core. If it a 775 then you might be able to use a Pentium D dual core w/ 800MHz FSB. If you have a 945 chipset then the above will be true.
