I am having problems with any new usb products such as new printers, micro sd card readers etc.. have tried the same device in other computer wuth no problems. Ive looked through some of the info on the microsoft web site and i seem to have the relevent usb 2.0 but i still cant seem to get it to work.
  • 849 Answers
You might have the old computer with usb 1, if u r using usb2 the it might not recognize on your computer or it may work slow
Posted on Nov 07, 2008
How do i transfer files from my cobra digital mini 150 to a pc?
Yes purchase an USB micro SD card reader.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Dec 09, 2012 | Cobra Digital Mini 150 5.0 Megapixel Mini...
Memory card locked
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts. ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
Oct 19, 2012 | Nikon D3000 Digital Camera
How do you put your micro sd card in the computer?
if theres a slot for an sd card on your computer you need a micro sd card adapter. if it doesnt have an sd card slot you need to buy a usb memory card reader (making sure it takes a micro sd card first)
both are widely available in supermarkets/electrical outlets or on ebay/amazon/play etc and are very inexpensive.
(micro sd adapter)
(memory card reader)
Aug 02, 2011 | Kingston 4GB Secure Digital High Capacity...
I have a LG dare cell phone and want to transfer some pictures to my Laptop. Lap top is running windows vista 64 bit. when I connect the usb the pc does not recognize the usb connection. It recognizes all...
Well, for music...
Install the supplied software for your Dare on your computer.
In "My Music" select "Sync".
You can now see your Dare as a USB device but only music is accessible. :{
For photos the easiest way is to use a micro SD card and a card reader.
Store or move photos from your internal memory on your Dare to the micro SD card.
Transfer the micro SD card to your computer with either a built in card reader or a USB card reader.
The next alternative is to use a program like BitPim which can be a little tricky and can delete or copy all of your personal data (images, tones, contacts, etc...) depending on which button you press. The two buttons look very similar. Great way to download free ring tones and upload to your phone for free.
Oct 27, 2009 | LG Dare VX9700 Cell Phone
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
2gb micro sd From Sandisk printer won't read.
From what info I have gathered is that my card reader on my printer is old and will not read that big of card. so off to the computer store to buy a new card reader.
Jan 19, 2009 | SanDisk 2GB microSD Memory Card
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
Problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
Does the micro sd card been detected by your computer? If not, you may try other card reader, or other computer. If still does not detected, you may try to go to device manager and see whether the sd card is there, if yes, then you can assign a drive letter to the sd card.
Once SD card shows as a drive letter on PC, you can download sd card recovery software to get back your files. recommended asoftech photo recovery that helped me before. download it from link below
SD Card Recovery Software
You can refer to this card recovery tutorial
Recover files from SD Card
If above does not work, you may have to format the memory card (use quick format), and then use Asoftech Data Recovery to scan again the memory card and recover your files.
Dec 09, 2008 | SanDisk 4GB microSD High Capacity Memory...
D900 mp3 problem
Just try formatting the SD card. Hope it works fine.
Just connect the micro SD with computer.(You need SD adapter, SD card reader, and USB connection) Most computer will recognise the SD card automatically. Format the micro SD in the Window Explorer(or My Computer). Format menu can be found if you click right-button with cursor on the drive letter. After formatting, re-insert micro SD into your D900.
Some Korean experts says the problem might be caused by different file system (e.g. FAT, FAT32, etc) in each memory card. So they recommended not to share your memory card with different mobile phones as well as any electric devices (eg. MP3 player and digital camera).
Nov 24, 2008 | Samsung SGH-D900 Cellular Phone
Problem with memory stick micro m2
is the card being read on the other device like camera/mobile etc.
if yes than card is okay
its the pc which is not compatible with your card. in this case u cannot do much but buy a card reader costing 5 usd
Apr 27, 2008 | SanDisk Memory Media
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
