Question about Canon PIXMA MP530 All-In-One InkJet Printer
MP530 Memory in use
I have a similar problem to others .... unable to send a fax on my MP530. Display says Mem in Use 0% when I position document. No memory light flashing. Cannot access Menu. Cannot switch to Copy either. Machine switched off and unplugged overnight but problem persists! Any advice please?
  • salesbj Nov 07, 2008
    Menu button unresponsive so unable to carry out suggested memory clear and restore
    Sergeant:
  • 306 Answers
Firstly, knowing your operating system would seem like cheating but would save all of us time. Vista likes us to waste time but most other Windows versions make it easy to see if your fax services are enabled. Go to Control Panel, Add/Remove Programs or Programs and features to see if you have the check boxes all checked. If you feel adventurous you can go to Start>Run>type mmc, Enter then add snap ons, choose services and see if any relevant services are disabled. Fax printers are also accessible in the Printers window where you can add a printer which is what fax really is More info gets you more help. your friend, Steve Medley
Posted on Nov 07, 2008
  • 102 Answers
Disconnect non standard fax protocol device (i.e. PC data modem, credit card machine, etc.) from line. The fax will only communicate with ITU-T standard fax protocol devices.
  • 83 Answers
Try to restore driver that will fix your problem
You can download the driver for vista from this link http://drivers.softpedia.com/progDownload/Canon-PIXMA-MP530-MP-Drivers-Vista32-110-Download-50611.html
thks
    Master:
  • 505 Answers
Check your ink cartridges and fill any that may be low. I got that error because one of the cartridges (magenta) needed to be refilled. The printer was storing failure reports in its memory until they could be printed out, leaving no room to fax new documents. As soon as the ink cartridge was replaced, the reports printed and freed up the memory to send out faxes.
Thanks
    President:
  • 1,952 Answers
You then have to power cycle the printer (hold down on/off for 1 second, wait 10 seconds, power on, wait for it to get ready (another 10-20 seconds).
  • mohammed marika thambi
    mohammed marika thambi Nov 15, 2008
    consult with ur authorised center and clear it
    Genius:
  • 1,269 Answers
How long have you had it? Initially you can try to disconnect the printer from the computer and do copy. Another thing is you can try to plug the printer to another compute. Also try to reinstall the printer software just like doing it from the scratch. Uninstall any previous printer driver and software.
  • Canon Master
  • 13,433 Answers
Clear the internal memory on the machine, perform a reset in the menu - restore to defaults, just clear out more memory in the device.
Says memory full but nothing in memory
Memory full errors can be caused by a couple of things. When you send a fax the machine settings and the amount of installed memory can cause this. Check the resolution you have the fax machine set at, usually it is set on something like "text" or "draft", if it is set on somthing like "fine" or "super fine" you will fill up the memory faster. Also if you are loading the document into memory before it actually connects with the other machine this could happen. Try looking for a switch or setting on your machine that says "direct". If you have a direct send enabled, your machine will not load the image into memory, it will wait for the other machine to answer and start receiving before actually doing any transmitting of the document. These are just general ideas as you did not describe the make or model of your machine. Hope this helps.
Larry
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Cannot fax ... Memory in use 0%
hii..
how long you have been using this fax.
Nov 07, 2008 | Canon PIXMA® MP530 All-In-One Printer
Faxing to several numbers
Sending Broadcasting Faxes:
Using the BROADCASTING BUTTON on the control panel you can use the broadcasting fax feature. 1. Load the document(s) face down into the ADF. 2. Adjust the document resolution to suit your fax needs.Press BROADCASTING on the control panel.4. Enter the number of the remote machine using the number keypad. 5. Press enter to confirm the number.The display ask you to enter another fax number to send the document. 6. To enter more fax numbers, press 1 to select "YES" and repeat steps 4 and 5. You can add up to 10 destinations. NOTE: You cannot use group dial numbers for another fax number. 7. When you finish entering fax numbers, press 2 to select "NO" at a "ANOTHER NO" prompt.
The document is scanned into memory before transmission. The display shows the memory capacity and the number of pages being stored in the memory.
The machine begins sending the document in order of the numbers you entered..Hope this helps
Oct 08, 2008 | Samsung SF-560 Plain Paper Laser Fax
Canon MP530 - Fax Not Working
sounds like the rollers need to have them cleaned little rubbing alcohol and soft non fiberous paper towel to help clean
there is also in fax a paper feeder that needs to cleaned its like the roller but usually only one roller this mechanical device pops up grabs next page and pushes it into fax
make sure pages arent static cling to each other this will also make a one page fax happen
example
when you take a staple out of packet your faxing put a little air between pages this is static cling
Feb 09, 2008 | Canon PIXMA® MP530 All-In-One Printer
Canon MP530 - Fax Memory is Full... How do I clear?
Dec 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon MIXPA MP530 Memory is full
I found this in a forum and I suspect it will work, remember that you'll need to clear the internal memory chip by unplugging the printer:
I got the dreaded "memory full" problem with my mp530 this morning. Couldn't FAX because the mp530 thought its memory was full even though it showed no documents in memory. The Canon site lists this symptom with a solution of 'turn off the unit, wait 10 seconds, then turn it back on'. Well that didn't work, so after multiple tries I noticed a post on this board (not really related) that suggested turning off the unit, unplugging it and waiting 10 minutes -- and that did the trick.
Dec 12, 2007 | Office Equipment & Supplies
Memory full display when trying ty fax
Thks for the above info. Went to my 530 to fix same problem and didn"t work. Mem in use light kept flashing. Re-traced phone line and outside line and found they were plugged into wrong jack. Moved the phone to the phone plug and outside line to outside line, and problem gone. This worked for me but there may be other causes that will make this happen
regards
oldcoot
Oct 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Fax in memory
Print from Fax Memory on MP530
1- Press Fax,then Menu.
2- Press the Right Arrow Key to show 'Memory Reference' on the mini screen.Then press OK.
3 - Again use the arrow keys to show 'Print Document' on mini screen and press OK to print.
4- Once this has printed repeat the first 2 steps and on the 3rd step go to 'Delete Document' to allow you to print the next saved fax.
5- Repeat this till you have no more Fax's saved,then the light should go out in the top left corner.
Hope this helps.
Oct 09, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
48 people viewed this question
old marine
old marine
