Question about NEC 1760NX-1 (White) 17 in. Flat Panel LCD Monitor
NEC Multisync 1760NX malfunction
Hello Kishkane,
I hope you can help.
I have an NEC Multisync 1760NX monitor that you have to flick the switch on and off several times in order to get it to come on; first it used to be two or three times, and then went to about five, and now it is out completely. It would seem that some sort of lighting lamp has malfunctioned, but I have no idea.
Any assistance would be highly appreciated
JM
  • knober1 Jan 06, 2009
    I have to flick the power switch off-n-on several times some times for half hour HELP
  • 105 Answers
I repaired mine by replacing C807, 22uF 50V capacitor in the power supply.
Monitor Mike
Posted on Jun 05, 2010
Xbox360 to NEC Display NEC MultiSync PA271W
You need a DVI to HDMI connector. You will need to connect the audio separately to your sound system as DVI does not support audio.
Dec 02, 2013 | Nec Display NEC MultiSync PA271W-BK - LCD...
Screen is yellow
Sound like you lost one of your colors (red, green, or blue). You can try an autosync function on the monitor, if there is one, or autocolor adjust, or something similar. But it sounds like the monitor LCD panel might be defective beyond repair. Youn can check your color levels. SOmetimes one will drop to zero for no reason. Try running your finger (pushing lightly on the LCD) around the edge of the monitor screen. Sometimes a transistor just gets stuck and you can close it back up. Keep track of where your finger is when the picture is correct, and home in on the exact spot. Then, just massage that area with your finger until the display looks right. That doesn't always work, but it's worth a try.
Mar 29, 2013 | NEC MultiSync 1760NX 17" LCD Monitor
How do you restart a nec lcd monitor, had power surge everything but monitor gets power?
The power surge probably blew the fuse inside the tv, first check the fuse inside the mains plug, if that is good then you will have to take the back cover off the tv, you are looking for the power board follow the mains cable into the tv and you will find it. Look for a fuse on the board, pop it out of the fuse holder, if you have or can get hold of a multimetre check the fuse for continuity if it hasnt you will have get hold off another fuse, you can normally get them from your local electrical repair shop, they dont cost much and the liklyhood is they will probably give you one free of charge.
Feb 04, 2010 | NEC MultiSync 1760NX 17" LCD Monitor
Multisync lcd1760nx This monitor powers up and works fine as far as I can tell. I set my notebook screen to show on this monitor as a clone screen(same image as my notebook screen). I cant see the image on...
Hi frnd.. there is a test known as Monitor self test to perform this just power on the monitor and unplug the flex cable.. U will see a logo bouncing up and down.. if this happens then it means the monitor is fine...
Sep 29, 2009 | NEC MultiSync 1760NX 17" LCD Monitor
NEC monitor drvier please !!
if you monitor turn on then not problem with monitor. it's related with your computer.
and what does it do when turning it on?
need more info for exact answer.
Mar 25, 2009 | NEC MultiSync FE991SB 19" CRT Monitor
Help Please!
power supply is bad on one of its legs(12 volt or 5 volt) you can have that bench tested at a service center or use a volt meter to check the output on the cables probably the 5 volt as the agp and the dvd roms cdroms etc need 5 volts to operate
May 01, 2008 | NEC MultiSync 1760NX 17" LCD Monitor
Apologies if you got this?? i dont know how this works???
Here is the link for your manual that will help you with your resolutions and screen position. Really easy. Nice monitor : http://www.necdisplay.com/cms/documents/UserManuals/LCD1760V_manual3.pdf
Mar 17, 2008 | NEC MultiSync 1760NX 17" LCD Monitor
NEC 1760NX-1 (White) 17 in. Flat Panel LCD Monitor Logo
309 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
