Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Cpu fan my cpu fan makes lots of noise . how can i fix it.i did clean it but it is stil the same
  • 6,487 Answers
If you're talking about the fan on your processor that is very noisy and you already clean it and still the same
you will need to replace the fan already because sooner or later that fan will not function properly anymore
and it will cause your system some overheating....
Don't forget to rate the solution FIXYA thank you...........
Posted on Nov 07, 2008
  • 928 Answers
You can also try some WD-40. Sometimes its just dirt. Remove the fan then spray some on and make sure its dry before you put it back in.
The fan is making an annoying noise
Usually, this occurs when the fan has accumulated dust. You should clean the area with a blower where is the cpu fan. If the noise persists, you must have replace your CPU fan latpop.
Regards!
Feb 21, 2013 | Acer 15.6-inch Aspire 5735-4774 Laptop LCD...
My cooler for my laptop wont work. it over heats and makes my laptop over heat also.
make sure the cooler fan is getting power test the leads that attach to the cooler make sure the connection is good and not faulty
also you should clean the cpu make sure there is no dust built up on the fins of the cpu
(dust will cause static) to computer overheat and lots of unforseen problems
also you purchase a portable usb laptop cooler pad
hope this helps
Mar 06, 2011 | Rocketfish Universal CPU Cooler RFUCPUCF...
Cpu fan is making much noise even i changed it.
First open your cup and clean the fan with vaccume cleaner.
and check the cpu fan speed if required change the cpu fan.
May 19, 2010 | Asrock 845GV (P4I45GV) Motherboard
My gateway model gx70183 will not power on or off. Fan was making a lot of noise and the computer quit
hi there, there is already problem on fan,noise of fans could develop overload current on system and this system is protected by overload protection,it will trip off of your cpu.replace fan where ever it was located,there is fans on Power supply unit(PSU) ,also in processor,also in video card,On PSU you can replace PSU,try to find another PC which is not use,use temporary the power supply to check if ignore the tripping of your pc.Also clean the terminals of your memory card by eraser head of pencil,also with the video card.have a nice day,dont forget to fix my rate,thanks a lot.
May 10, 2010 | Computers & Internet
The fan in modem makes loud noises at times
Modems don't have fans.
I think you mean your fan in the computer makes a loud noise. Some computers have settings where the fan speeds up if you are doing a lot of things--making the computer work harder.
Some fans make noise just before they fail. Depends on the type of noise. If it's a sound that has a lot of rattling in it or maybe a high screeching sound, I'm thinking you'll be needing a new fan. Probably a CPU fan is the culprit. Also, fans on video cards often go bad--so you'll have to open the case and listen to where the sound comes from.
Oct 25, 2009 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
Msi vr610 fan very noisy.how do i cure, get new part
Its a typical failure of MSI fans from those times. Unfortunately the exchange part will not solve your problem. (I read it in comments lots of times.) I own a VR610 and fixed the problem with grease. I disassembled the fan and took out the paddle wheel. I cleaned the pin and the hole both and filled the hole with grease. I used small portion of (lithium based) grease like on bicycle. The fan is noiseless since 1,5 years. :)
Sep 29, 2009 | MSI VR601 Notebook
The cpu fan wont run--i cleaned it with air can--if i hold the start button down it will stay running but make a lot of noise--when i let up on the switch it will die--i think the cpu fan burnt out causing...
Try replacing the fan first, and see if the computer starts, and runs normally, otherwise you could have fried the CPU. In that case a new processor is needed.
Aug 04, 2009 | ASUS Computers & Internet
Emachines e3415 problem
I would guess that the CPU overheated if the fans are noisy. I would remove the CPU heatsink clean and reinstall the CPU with the proper contact paste,reinstall the Heatsink along with a new heat sink fan, if that is the one is making noise also.  Then see if it will then boot up. If not I am guessing that the CPU was damaged for the fans not workingwell enough.
Dec 21, 2008 | E-Machines eMachines Desktop PC
My CPU is making lot of noise especially when I'm using programs like Adobe reader
The CPU wont make noise unless its frying. So its either your hard drives, cd drives, or your fans.
If its your fans i sugest buying newer "Cool Master" fans that are powerful but less noisy
Oct 20, 2008 | Mesh 80mm Aluminum Fan Filter Fan Kit
Sony vaio cpu is makes a lot of noise
im not 100% sure nut i think its the power supply cause some power supplys are very noisy and it might be why the cpu is overheating
Aug 09, 2008 | Sony VAIO PCV-RS720G (027242658103) PC...
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
