No power but theres B+ - Televison & Video
  • 2 more comments
  • Anonymous Dec 08, 2008
    no power
  • frankhawaii Dec 09, 2008
    Turned Tv off, from power strip, and did not turned back on, all others s stereo, cable box came back on, except the TV
  • budfans Dec 15, 2008
    you push the power button the freen lights up for about 2 seconds and goes off !
  • mariom73 Jan 14, 2009
    Mine has the stand bye button blinking on and off
Same situation here, there is a small glass buss fuse (4v 3.25amp), on the lower end of the circut board witch pulls out like a servign try after you have removed outer casing (back) and unplugged speaker connection. check exact size of fuse before replacing some systems use different sizes. this is a quick fix solution i hopw it works for you.
Posted on Dec 14, 2008
I have put a new fusion but still have no power no light nothing dead can you tell me what's going on please
Wear thick rubber gloves. Remove cover where fuse is. Use volt meter to see if power is flowing to fuse. If not you have a short going there. If there is power there, then check to see if the is power going to switch. If there is power to switch, turn on (BE CAREFUL!!! STAY OUT OF HARMS WAY) Check to see if there is power at motor, if no power, the power switch needs replacing. If there is power coming from switch and the motor is not on then the motor needs replacing.
May 15, 2016 | Cars & Trucks
Starter clicks but won't turn over the edngine
Hi, the starter is malfunctioning. It could also be a ignition issue as well, here is a quick starter test procedure that will help you troubleshoot a bit.
Check for 12 volts on the large wire attached to the top terminal on the starter relay. It should have battery voltage. If not, the battery, terminals or wire is bad.
Check the small wire on the solenoid for power when the key is in the start position. Remove the small wire on the solenoid and have a helper hold the key in the start position. Check the wire for battery voltage. If there is voltage, the starter is bad. If there is no voltage, replace the wire.
Check the fuse in the fuse box under the hood on the left fender well. If it is good, check the relay by pulling it out and checking for power at one terminal with the key off. If there is no power, the problem is in the fuse box between the fuse and the relay. If there is power, have the helper hold the key in the start position once again and check for power at another terminal from the ignition key. If there is power, the relay is bad. If there is no power, the starter circuit is suspect.
Check to see if there is power to the neutral safety switch if there is no power at the relay. Use the voltmeter to check for power with the key in start. If there is power going in, check for power going out. If there is no power going in, the security system or ignition switch is suspect. If there is power going in and none coming out, the switch is bad. If there is power coming out, the problem is between the neutral switch and the relay.
Remove the cover on the bottom of the steering column. Check the solid yellow wire for power when the key is in the start position. If there is no power, the ignition switch is bad.
May 31, 2011 | 1991 Dodge Power Ram 50
1995 aerostar i have lights radio works turn key to start engine nothing
HI. This could be as simple as a faulty wire or a bad ignition switch assembly. Use the procedure below to isolate the culprit.
1.Check for 12 volts on the large wire attached to the top terminal on the starter relay. It should have battery voltage. If not, the battery, terminals or wire is bad.
2.Check the small wire on the solenoid for power when the key is in the start position. Remove the small wire on the solenoid and have an assistant hold the key in the start position. Check the wire for battery voltage. If there is voltage, the starter is bad. If there is no voltage, replace the wire.
3.Check the fuse in the fuse box under the hood on the left fender well. If it is good, check the relay by pulling it out and checking for power at one terminal with the key off. If there is no power, the problem is in the fuse box between the fuse and the relay. If there is power, have the helper hold the key in the start position once again and check for power at another terminal from the ignition key. If there is power, the relay is bad. If there is no power, the starter circuit is suspect.
4.Check to see if there is power to the neutral safety switch if there is no power at the relay. Use the voltmeter to check for power with the key in start. If there is power going in, check for power going out. If there is no power going in, the security system or ignition switch is suspect. If there is power going in and none coming out, the switch is bad. If there is power coming out, the problem is between the neutral switch and the relay.
5 Remove the cover on the bottom of the steering column. Check the solid yellow wire for power when the key is in the start position. If there is no power, the ignition switch is bad.
Nov 29, 2010 | 1995 Ford Aerostar
What other than starter or voltage regulator would not let 1966 buick skylark turnover
2.Check the small wire on the solenoid for power when the key is in the start position. Remove the small wire on the solenoid and have a helper hold the key in the start position. Check the wire for battery voltage. If there is voltage, the starter is bad. If there is no voltage, replace the wire.
Aug 21, 2010 | Buick Skylark Cars & Trucks
I turn the ignition and get a clicking sound. What should I be checking?
The starter is malfunctioning at this time. it could also eb a ignition issue as well. here is a quick starter test procedure that will help you troubleshoot a bit.
Step 1
Step 2
Step 3
Step 4
Step 5
Jan 05, 2010 | 2000 Chevrolet Silverado
Wont start starter wont engage new batter fuses ok
The starter is malfunction at this time. it could also eb a ignition issue as well. here is a quick starter test procedure that will help you troubleshoot a bit.
Step 1
Step 2
Step 3
Step 4
Step 5
Nov 27, 2009 | 1998 Pontiac Grand Prix
66 mustang only clicks when trying start, battery and cables check ok
Step 1
Step 2
Step 3
Step 4
Step 5
Nov 25, 2009 | 1966 Ford Mustang
My van doesn't start, it has a new battery and starter.
The starter is malfunction at this time. it could also be a ignition issue as well. here is a quick starter test procedure that will help you troubleshoot a bit.
Step 1
Step 2
Step 3
Step 4
Step 5
Nov 20, 2009 | 1999 Plymouth Grand Voyager
Problem with starter
HI. the starter is malfunction at this time. it could also be a ignition issue as well. here is a quick starter test procedure that will help you troubleshoot a bit.
Step 1
Step 2
Step 3
Step 4
Step 5
Sep 10, 2009 | 1994 Chevrolet Caprice Classic
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
