E4 54037380 Cannot record to disc? - Televison & Video
  • F5ChaserRain May 13, 2009
    I have a Phillips DVD Player/Recorder DVDR3505 that is coming up with the same problem. I can get it to unfreeze by unplugging it but recording is another issue. I have tried it on 6 or more discs to get it to work. Need help badly.
  • 4 Answers
This seems to be a common problem on all DVD players
If a DVD Lens cleaner (with brushes) fails to fix the problem, then it could be that you have
grease particles on the lens. Do the following:
Note. If unit is still under warranty, you may nullify this by opening unit up
You will need:
Screwdrivers as necessary
Cotton Bud sticks (also known as Q-tips)
Isoproponal/Isopropyl Alcohol (small bottle comes with some CD/DVD cleaners)
Compressed Air cannister/aerosol
1. After disconnecting unit, leave standing for 15 minutes
2. Unscrew lid and remove
3. Carefully remove DVD lens cover
4. Blast whole area with compressed air to remove dust
5. Dip one end of cotton bud in Isoproponal, and very carefully wipe DVD lens (just one wipe
should do.)
6. Now wipe lens with dry end of cotton bud, and leave a few seconds to dry
7. Carefully replace DVD lens cover (watch out for ribbon cables)
8. Replace Lid
9. Reconnect, switch on and test
After I'd tried every other way possible, this method finally worked for me!
Posted on Nov 11, 2009
RECORDED DISCS NOT PLAYING BACK ON OTHER DEVICES
Did you finalize the disc on the DVD recorder that burned the file? Without more information on your DVD recorder, I can't give you exact directions to find the command on your unit. On my DVD/VCR, after recording, I usually finalize a disc before removing it from the recorder. On mine, I press Menu and go to Disc. I add a title (optional) and then select the Finalize option. Then accept the finalization (which makes it impossible to add more to the disc). For -RW discs, you can unfinalize and then reformat them. Write once discs are permanently stored.
What type of disc did you record to? Some other players may not recognize DVD+R or DVD-R discs or DL discs. Check the specs on the other players and try different brands/types of discs for future recording.
If you add a comment with the type of DVD recorder used to burn the problem discs, I may be able to give additional advice.
Oct 25, 2011 | Televison & Video
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
Device will not play previously recorded discs or record new info,but will play shop bought discs.on occasions it will display disc error. i am using new discs.
I Have had this same problem with DVD recorders. They sometimes will not play disc that were recorded on another player, you have to play these on the recorder that you used to make the recording. When recording you must finalize the discs to get them to play in other recorders, if they aren't finalized then the dvd wont recognize them as being recorded, there is no starting point set on the disc for the laser to pick up on. I have also ran into discs bought at the store that were not any good and I couldn't record on them, or when I did I would get the disc error message also. Try another brand of disc,say Memorex or Soney amd see if these will work, make sure they are compatible with the player, and they are the correct format for your player. There are 2 types DVD -R and DVD + R the + R work better on a wider range of players.
Nov 25, 2010 | Philips DVDR880 DVD Recorder
For sony rcd-w500c/w100 won't go to record mode.
Make sure you're using CD-R AUDIO or MUSIC blank discs. It won't record onto data discs.
Jul 20, 2010 | Sony RCD-W500C 5-Disc CD Recorder
Cant get pre-recorded disc's to play in my recorder it comes up with the message "this disc will neither play or record" any ideas?
hello,
the reason the recorder comes up with the message "this disc wont play or record" simply is that the format of the disc is not compatible with the player.
1. check the format of the recorded disc,
2. and check the formats the recorder can play to confirm this.
take care
Jun 03, 2010 | Sony RDR-VX420 DVD Recorder/VCR
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Invalid disc prompt,whenever i install a disc
This is a dedicated audio recorder. Therefore, you must use dedicated audio discs (not data discs). You can tell the difference as audio discs specify the recording time (usually 80mins) instead of data capacity (usually 700MB).
When you have the right disc inserted, press the record button & it will go into record standby, ready to record. First, set a level, then press record again, and you are recording.
Jan 09, 2008 | KLH CDR2000 2-Disc CD Recorder
Recording to cd
Disc recover occurs when the power goes off and comes back on halfway through a disc being recorded. Try a new disc? You may have a faulty PCB on the record side.
Dec 02, 2007 | Philips CDR795 2-Disc CD Recorder
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Televison & Video Logo
301 people viewed this question
Top Televison & Video Experts
Electro Med Services...
