Question about Dishwashers
Maytag quiet series 300 MDBH955AWW won't clean my dishes!
My machine won't clean my dishes! The food particles are still in my dishes and in the later left in the bottom of the washer after a ( so called ) wash cycle. I researched a little more and discovered that all the sprayer arms are not turning. Water is coming out of them but it seem like there is a loss of pressure. I can't fully tell because I can't watch the dishwasher work while it is running. I took apart the washer all the way down to the moter. I didn't know what to look for. But, I wanted to see how it worked. And see if there was anything clogged in there. I cleaned it up and discovered nothing. Of course I didn't know what to look for in my situation. It did make some loud clicking sounds and grinding noises about a month ago. The machine is about 2 to 3 years old. It doesn't seem like it is draining right or getting enough water pressure. That is my guess. Anybody familiar with my situation? Please help!
Thanks...
  • Anonymous Feb 17, 2009
    I have a Maytag mdb9100aww doing the same thing. Water pressure seems fine, When I open the door after running, I see the jets still blowing water, but the arm does not turn. I've taken the lower wash arm off, along with the filter guard, and secondary filter and cleaned everything thoroughly, but to no avail. Is there a motor that turns the lower wash arm, or it simply by water pressure?
  • Kate09190 Apr 21, 2009
    I have the same dishwasher but a slightly different problem, sorry -- I also have a Maytag Quiet Series 300, I do not know how to clean out the filter and it seems to be not getting the dishes all the way clean and re-depositing food from the filter into the bottoms of cups and on dishes. At the bottom of the dishwasher there were food particles around the large circle and on the bottom just inside the door. I cleaned that out but it still doesn't seem to be getting everything clean. Is there a filter somewhere else I can clean out?
    Please let me know at: Kate09190@aol.com
    Thanks. :)
  • 3 Answers
I have this model. They have been recalled due to a heating element problem - possible fire hazard. You need to check to see if the ending letters in the serial are NL. Contact Maytag via website www.repair.maytag.com or the phone 1.800.544.5513. I think I had the same problems as all of you and the solution was to call the pros and find out. I needed to have a special hook-up in my plumbing installed. It was a T fitting or something. The water flow was not coming out right, so it vomitted back down on itself. Basically the plumbing under my sink had to be re-done so the flow was correct. Not problem after that. Good luck, sometimes DIY doesn't always work.
Posted on Sep 17, 2010
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Jan 15, 2010 | Maytag Washing Machines
Doesn't get dishes clean soap doesn't even rinse off
use less soap and you have to pre wash your dishes it is a washer not a food grinder
Dec 06, 2009 | Dishwashers
Exactly the same! Maytag Model MDBH955AWW Quiet Series 300
i would say it's a serious internal problem ...not a simple fix ...call for service
Jul 26, 2009 | Maytag 24 in. MDBH955AW Built-in...
Maytag Quiet Series 100, Model # MDB5600AWS, built in dishwasher. Does not get the dishes clean, dishes stay dirty after multiple cycles of washing. Please help!
We also have a Quiet series 100 and had the same problem, the dishes always came out dingy or with food all over them. My washer is about 5 years old and worked well for about 4 of them but the last year has been doing a poorer and poorer job washing the dishes. I finally broke down and removed the racks and all of the plastic parts from the inside of the washer. Doing this revealed that the groves in the under side of most of the plastic parts was clogged with food and debris. After a good scrubbing with water and a brush then reassembly it worked like a new washer again, cleaning the dishes very well and the best part is it saved us about $700.00 for another washer.
Jun 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag dishwasher legacy 300 quiet series
Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Maytag quiet series 300 - sandy residue
the buttons to start the cycle auto clean or heavy wash does not light up and therefore is not cleaning my disches please advise to
Carol @ killday@irtc.net
Apr 06, 2008 | Maytag 24 in. MDB9750AW Dishwasher
Maytag quiet series 300 dishwasher
try using less soap and make sure the dishwasher is filling with enough water.
Mar 02, 2008 | Dishwashers
Dishwashers Logo
2,880 people viewed this question
Top Dishwashers Experts
