Question about Dishwashers
Maytag quiet series 300 won't clean my dishes!
My machine won't clean my dishes! The food particles are still in my dishes and in the later left in the bottom of the washer after a ( so called ) wash cycle. I researched a little more and discovered that all the sprayer arms are not turning. Water is coming out of them but it seem like there is a loss of pressure. I can't fully tell because I can't watch the dishwasher work while it is running. I took apart the washer all the way down to the moter. I didn't know what to look for. But, I wanted to see how it worked. And see if there was anything clogged in there. I cleaned it up and discovered nothing. Of course I didn't know what to look for in my situation. It did make some loud clicking sounds and grinding noises about a month ago. The machine is about 2 to 3 years old. It doesn't seem like it is draining right or getting enough water pressure. That is my guess. Anybody familiar with my situation? Please help!
Thanks...
  • 2 more comments
  • Anonymous Dec 08, 2008
    Same thing this is not okay
  • Anonymous Dec 14, 2008
    Me too. Same thing.
  • camarocloud Jan 08, 2009
    Same here. High pitched grinding/buzzing with clicking almost as if is about to short out??? I have not heard the noise in a while but now it is not cleaning properly. Degree of clean seems to vary from lots of caked on food to just small particles being left on dishes. I read a post that said it wasn't getting enough water and have tried adding 2-3 extra quarts of water and it seems to help but is not cleaning as well as when I got a year and a half ago. It seems to me the spray arms are not working properly. This is the second of the same model I've had. The first one had a crack/cut in the top of the tub and had been slowly ruining my kitchen, which I discovered 13 months after I got it. After a $5,000 kitchen remodel, my home owners insurance paid for, they gave me a new machine. I'd had no problems with the first one (except the leak) and really loved it. Any help appreciated.
  • Kate09190 Apr 21, 2009
    Same problem. What to do about this. Is there a filter somewhere we are missing?
  • 3 Answers
SOURCE: Maytag quiet series 300 MDBH955AWW won't clean my dishes!
I have this model. They have been recalled due to a heating element problem - possible fire hazard. You need to check to see if the ending letters in the serial are NL. Contact Maytag via website www.repair.maytag.com or the phone 1.800.544.5513. I think I had the same problems as all of you and the solution was to call the pros and find out. I needed to have a special hook-up in my plumbing installed. It was a T fitting or something. The water flow was not coming out right, so it vomitted back down on itself. Basically the plumbing under my sink had to be re-done so the flow was correct. Not problem after that. Good luck, sometimes DIY doesn't always work.
Posted on Sep 17, 2010
Dishwasher drain pump flapper (inlet side)
My Quiet Series does the same thing and I wondered if the orange flapper has gone bad and lets the dirty water drain back from the hose sloping up to the garbage disposal. Did you get an answer to this question? The dishwasher seemed to work fine and then it suddenly started leaving food particles on the glasses.
Jan 15, 2010 | Dishwashers
Doesn't get dishes clean soap doesn't even rinse off
use less soap and you have to pre wash your dishes it is a washer not a food grinder
Dec 06, 2009 | Dishwashers
Maytag Quiet Series 100, Model # MDB5600AWS, built in dishwasher. Does not get the dishes clean, dishes stay dirty after multiple cycles of washing. Please help!
We also have a Quiet series 100 and had the same problem, the dishes always came out dingy or with food all over them. My washer is about 5 years old and worked well for about 4 of them but the last year has been doing a poorer and poorer job washing the dishes. I finally broke down and removed the racks and all of the plastic parts from the inside of the washer. Doing this revealed that the groves in the under side of most of the plastic parts was clogged with food and debris. After a good scrubbing with water and a brush then reassembly it worked like a new washer again, cleaning the dishes very well and the best part is it saved us about $700.00 for another washer.
Jun 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag dishwasher legacy 300 quiet series
Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Nov 07, 2008 | Dishwashers
Maytag quiet series 300 - sandy residue
the buttons to start the cycle auto clean or heavy wash does not light up and therefore is not cleaning my disches please advise to
Carol @ killday@irtc.net
Apr 06, 2008 | Maytag 24 in. MDB9750AW Dishwasher
Maytag quiet series 300 dishwasher
try using less soap and make sure the dishwasher is filling with enough water.
Mar 02, 2008 | Dishwashers
Dishwashers Logo
551 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
