Question about Whirlpool Refrigerators
I connected the water supply to my fridge but I am not getting water from the door. Also, normally when I push the lever in the door for the ice, I can hear it turning inside to push the ice out, but this is not the case now. What do you think is my problem?
  • 108 Answers
Obviously this is a problem with the water supply. Check the flow to the ice maker. Is there a kink in your tubing? All of this makes sense.
Ray..
Posted on Nov 07, 2008
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Why is the water running directly into the ice dispenser and running out of the door when we are not pushing the lever to get water?
Sounds like the water valve is stuck or the wiring or switch is defective. As both ice and water are a problem it sounds more like a defective water valve.
Oct 05, 2014 | Whirlpool Refrigerators
Water works but ice will not dispense
Check the top of the fridge. The hinge on the left where the door is there should be a wire harness on the top, but on this fridge it might be at the bottom. Inspect all the wires to see physical damage of sorts. Then if you can, tug on them while someone holds the dispenser. You might need a whole new door if it's not the Mainboard.
Mar 15, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I described the problem poorly, I apologize. The freezer and fridge are at the proper temperature (freezer is at 0, fridge at 40). I've checked and the water flow from the wall into the machine is good...
Hello David ,
Their are a few possible reason the ice is not being dispensed,
1) the door switch is bad...the door must be closed for the ice to dispense and perhaps the switch thinks the door is open
2) the switch that is activated when pushing the lever on the dispenser is bad
3) the dispenser motor is bad
4) the control board is bad
GENE
Sep 23, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Water button lights up green but no water comes out when you push the lever
Hi. Check to be sure that the fridge has the water supply connection made. It is on the back of the fridge. Often, a 1/4 inch plastic or copper line runs from the back of the fridge to under the sink. There would then be a small faucet at that connection which would have to be turned on. j.
Jul 10, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
Water dispenses very slowly on Fridge
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The coil of tubing is normal so you can move the fridge out from the wall without damaging anything.
Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 14, 2010 | Refrigerators
Ge fridge, water and ice on the door ,, all of a sudden the waterstopped working on the door ,, but it still makes ice
There is a double water valve in the back of your frige that your water supply connects to at the bottom. You will need to replace this valve. It will have your water supply connect on one end and two lines connected to the other. You can test it to be sure by doing this. Disconnect the two lines that are on one side. Using a towel to catch the water, have someone push the leaver in the front of your frige that you push when you want water. If the valve is good water will come out at the pressure you normally have when you are filling a glass from the front. If it does not come out, you will need to replace the valve.
Aug 15, 2009 | GE Refrigerators
WATER WON'T COME OUT OF THE DISPENSER IN THE DOOR
Check the solenoid valve in the back of the fridge near the water supply connection. If you don't hear any clicking from back there when you press the lever, then the valve is probably bad. Open the back and look for two valves in an assembly - one for ice and one for water. Sometimes the solenoid coil burns open in one or the other, and you have to replace the whole assembly. You can disconnect the solenoids and check for continuity with an ohmeter. It's not a complicated repair. Good luck!
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS25L GE no water
Check the electrical connector that is next to the water pipe at the bottom of the freezer door
Aug 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
