Maytag washing machime will not agitate or spin
Maytag Model MAV6000 will not agitate or spin it fills and drains ok belt looks ok and turns
  • 61 Answers
SOURCE: Maytag MAV6000 Top Load Washing Machine
Tip the machine back remove the belt try to turn the drive pulley manually . sorry the larger pulley in the centre. if you can turn it counter clockwise and feel the inner drum moving then the thrust bearing is ok. if not you may need to replace it.Also a bad lid switch can cause this problem.
Posted on Dec 18, 2008
appldoctom
  • 311 Answers
SOURCE: How to replace a belt on a Maytag MAV6000 washing machine
hey good for you thats an eazy one .pull the washer out abit and then tip so the top resting on wall behind.be careful dose not slip out from under but ihave done it a hundred times as a repairman.before replacing the belt inspect the motor pulley,its plastic and they do melt.also inspect the pump pulley making sure it turns freely and the spot welds are not broken joinning the pulley to the pump shaft...........other wise just spin the old belt off and spin the new belt on.the belt goes on a total of three pulleys .thats it if you need any other help you can email . God bless ,tom
Posted on Jan 08, 2009
  • 25 Answers
SOURCE: Describe your Maytag Atlantis MAV6000 Top LoaI
drive unit faulty/or faulty lid microswitch
Posted on Jul 13, 2009
SOURCE: maytag will agitate instead of spin
http://allrepairmanuals.com/maytag-washer.htm?model_number=MAV7901AWW
Please download, the above, service manual, use the troubleshooting procedures, you should be able to locate and repair your problem.
Posted on May 05, 2010
jumptrout51
  • 3361 Answers
SOURCE: we have a maytag mav6000 will not agitate or spin.
Use a volt/ohm meter to check the lid switch for continuity.
Posted on Jul 24, 2010
I have a Maytag Atlantis MAV6200AWW Washer agitates and spins. Water sometimes empties. Pump is fine spins freely and the impeller is fine. Could it be the belt ?
You will need to check for an article of clothing stuck between the basket and tub that may be partially blocking the drain hole.
Nov 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Maytag will agitate instead of spin
May 05, 2010 | Maytag Neptune Washer
Washer will not drain or spin out.
look underneath is the belt attached? if so then there is something in the hose from the tub to the pump.
Apr 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine won't agitate
it sounds like the transmission is shot. Not knowing the cost of parts if you can replace the transmission yourself then yes it could be worth fixing however if you can't do the job yourself adding cost of parts and labor it may not be worth it
Jan 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Nov 07, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
Jun 02, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
