Question about ECS 945GZT-M (V1.0) Motherboard
IDE HD Not Detected
From one boot to the next my XP fails to detect my hard drive as Primary Master.
My HD is now listed as IDE Third Master.
I have not changed anything.
Went into BIOS - everything set to auto-detect but still will not recognize my HD as Master. The setup is about 8 months old.
  • herdex Nov 19, 2008
    motherboard ecs 945GZT-M cannot read HDD also CD ROM I hope information is way of the solving of in detail
    can you send to my email herdex01@yahoo.com.
    Scholar:
  • 57 Answers
My first thought is the cables have been moved or the drives moved. Maybe the jumper has fallen off the back of the drive (highly unlikely, but possible) or maybe a cable has come loose. It can't hurt to reseat all the cables and check the jumpers to see that all are correctly jumpered as master and slave.
herdex may not have the same problem, but will email this suggestion to him.
Posted on Jan 23, 2009
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
I formatted my hd making it slave in other system: now i m placing it back on my system then it is saying Primary IDE masterNONE; Primary IDE Slave SP0822N Then comes NTLDR MISSING
> formatted my HD
This deleted 99% of the files on the disk-drive.
> Primary IDE Master: NONE
> Primary IDE Slave: SP0822N
Good. Your motherboard has detected ONE disk-drive.
Do you have just one connected disk-drive on your PRIMARY channel, or do you have two connected disk-drives (via the 2 connectors on the one ribbon-cable on the PRIMARY channel) ?
If you have two drives connected via one ribbon-cable, you MUST set the 'master/slave/cable-select' jumpers on BOTH disk-drives, to identify which of the two will be the 'master' and which will be the 'slave'.
Also, check that the 'second' disk-drive is getting electrical power.
> NTLDR MISSING
Like I said, you deleted 99% of the files, including the 'NTLDR' file.
Your computer is trying to "boot" from the 1% of the files that still exist on the disk-drive, but cannot find the now-deleted file.
Perfectly normal, given that you have formatted the disk.
Oct 06, 2010 | Samsung (SP0822N) 80 GB Hard Drive
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
Trying to install Windows XP SP1 onto HD with this Motherboard. System will not boot from HD to start install.
Make sure your IDE hard disk drive is connected to IDE1 port and that the data cable is fully connected. Also check the jumper on the IDE drive. If you are using only one IDE hard disk drive set the jumper on the drive as a Master without a slave. If you are running two IDE hard disk drives set the primary drive's jumper as a Master with a slave. Set your second IDE disk drive's jumper as a slave. The master drive should be connected at the end of the data cable and the slave drive should be connected to the next data connector. Than check your bios settings. Power on the system and press the Delete key every 2 seconds until the bios menu loads. See page 3-1 in your manual. If you need the manual for the NF8-V MB click on the link provided below and download it;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF8-V&fMTYPE=Socket+754
You'll also need the program Adobe reader to view the manual. Adobe reader is a free download; http://www.adobe.com/products/reader/
Once you’re in the bios go to page 3-4, Standard CMOS Features.
Follow the instruction listed for IDE HDD Auto-Detection. Your HDD should be listed here. Than see page 3-7 in the manual. Open Advanced BIOS Features. A normal boot menu for the Abit would read;
First boot device Floppy disk drive (If one is connected). 2nd boot device should be (CD-ROM/DVD-ROM). Third boot device should list your primary hard disk drive's (Model number). Load your windows CD into your CD-ROM drive.
Once the settings above are set, press the F10 key to save your changes and exit the bios. Your system will auto restart. Windows should begin to load.
Cheers!
Mike
Nov 18, 2009 | Abit NF8-V Motherboard
Boot error always
Hello sir, hi your boot error can be caused by the following:
  1. Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
  2. Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
  3. IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
  4. Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
  5. Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
  6. Your IDE ribbon cable is bad.
  7. Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
Nov 08, 2009 | ASUS P4S8X-X Motherboard
2nd Hard drive not recognized
If your using IDE hard drives i would try to put them both on the same cable on the primary IDE controller. Then set you main hard drives jumpers and the second hard drive to cable select not slave. Try to boot if the boot fails your goiong to need a Windows 98 boot floppy with FDISK. You need to start up the 98 boot disk with out CD support then when it reaches a command prompt start fdisk. ONce fdisk is up format and partition the second drive. Now it should work. :) Check that the harddrive is detected in the BIOS, it may have become disconnected, it should also be the master drive on the primary IDE. If the drive is not detected in BIOS there is little chance of it working
Thank you....
Jan 29, 2009 | IBM ThinkPad X31 2672 Notebook
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
ECS 945GZT-M (V1.0) Motherboard Logo
102 people viewed this question
Top ECS Computers & Internet Experts
David
David
mitch_3020
mitch_3020
Greg Cann
Greg Cann
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
