Question about Brother IntelliFAX 5750e Laser Fax
Printer online message
Cannot clear and will not print or fax
  • Anonymous May 20, 2009
    Printer on line message is on the unit and will not print out faxes. Have unplugged for 2 min and still the same thing
I have this same problem can you help me?
Posted on Dec 10, 2008
  • 2,120 Answers
Unplug the power cord for 10 seconds.
Posted on Nov 07, 2008
Fax memory full lexmark x
Memory full, cannot send faxes
The printer fax memory is full. Press the check mark button to clear the message and cancel the fax.
• Reduce the fax resolution and try to send the fax again.
• Reduce the number of pages in the fax and try to send the fax again.
Jul 09, 2014 | Lexmark X364dn All-In-One Laser Printer
I keep getting message that my Canon Printer Pixma iP3000 'is offline'. How do I get it to be 'online' so it can proceed to print the 2 documenys on the printing queue?
Here's the steps in order for you to get your printer ONLINE and be able to print.
1. Click on your START menu
2. SETTINGS / Printers and FAXES or via COTNROL PANEL, printers and faxes
3. RIGHT click on your printer
4. Make sure "Use Printer Offline" is NOT ticked, if it is, UNtick it
Your printer should respond immediately if there are documents on queue for printing and should print it out.
Hope this helps!
Good Luck!
Mar 14, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
I have lexmark x7170 all in one printer and i can't receive faxes it says memory full but when i try clearing it it says no pending faxes so i cam't. What can i do?
This temporary storage of fax may happen when one of your cartridge is detected low ink level. Try to replace your low ink cartridge. Sadly, if you have navigated away from the fax menu after inserting a new cartridge or clearing the message, you may lose the fax. You can try to have the sender resend the message. When this problem happens again, just replace your cartridge without turning off your printer. Once inserted, accept the incoming fax message to print it.
Feb 16, 2011 | Lexmark X7170 All-In-One InkJet Printer
8500 hp printer -- cant get red of message -fax log full
clear the fax log...
go to setup menu basic fax setup... scroll to fax log... clear fax log....
in some printer you can find the fax log in the fax settings or advance fax setup..
Feb 16, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Fax machine says: Printing Online on its LCD readout but won't print anything. We have replaced the drum and the toner. We can't get the message to clear either
Press "Menu" & "Mode" keys. Display should clear. Then press 0, enter 91. Hit stop after completion. THIS WILL CLEAR ANYTHING IN MEMORY.
Aug 17, 2010 | Brother IntelliFax-4100e Fax
The paper is stuck while printing and the message is clear the paper jam
when it stuck, just click start menu below, under settings and printers and faxes. Then find the printer and double click and cancel all documents clear. So after doing it restart again your pc and try print another document.
May 09, 2009 | Office Equipment & Supplies
Unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2. If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine...
Dec 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother IntelliFAX 5750e Laser Fax Logo
140 people viewed this question
James Cagle
James Cagle
Jim Keysor
