Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
Maytag 300 Quiet Series Dishwasher
My dishwasher appears to not be draining properly. After each complete cycle there is water in the bottom of the tub. Model #MDBH965AWW My maytag quiet series 300 mdbh955aww is not cleaning my dishes! There is always dirty water left in the bottom of the washer after a cycle. I discovered that the sprayer arms are not turning on the rack, bottom, or top. It seems like there is not enough water pressure. I took the machine apart down to the motor. I didn't notice anything wrong, but I didn't know what to look for. Also, lately it has been making this horrible clicking and grinding noise. Any suggestions?
Thanks, Christine .
  • 4 more comments
  • fleyba03 Nov 12, 2008
    my maytag 300 quiet series does not drain
  • Anonymous Nov 22, 2008
    I have the same exact problems FRUSTRATING
  • beatricemacd Dec 27, 2008
    grit is left behind on my dishes!
  • joebarnold Jan 01, 2009
    We have the exact problem and I have done everything. It will pump out on rinse but not on wash cyles!
  • av8tr279 Jan 09, 2009
    1. mine grinds and groans. anyone know what is wrong?
  • dwc2u49 Mar 24, 2009
    wands are not spinning dishes are always left dirty. Pump is working, drain is working. There is some calcium build up on parts.Cleaned best I could.
SOURCE: Maytag 300 Quiet Series Dishwasher
Unit will not turn on..had this unit for 6 months..worked fine..all of a sudden wont turn on now..checked power and connections..all were stumped..just wont turn on.
Posted on Feb 26, 2008
  • 188 Answers
SOURCE: whirlpool quiet partner II top rack sprayer doesnt
The top rack spray arm doesn't work because of low water pressure from the wash motor or it's clogged with debris.
If the top spray arm looks clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Posted on Apr 03, 2009
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
  • 37 Answers
SOURCE: Maytag Quiet Series 300 smells broken door latch and lower rack
I have had the same problem and there is a simple fix.
The problem in my case was the floating water sensor was stuck and gummed up with grease.
On the bottom of the dishwasher, in the front right corner there is a round doughnut-looking thing. This is the water level sensor. It is open on the bottom, and grease collects there.
When this happens, the air pocket is too small, and the float won't float. then the dishwasher overflows. To clean it: just reach under with your finger, and scoop out the grease.
Sometimes, after doing this, the float then gets stuck in the "up" position. When this happens, the dishwasher completely drains, and the heater element for the dishwasher is exposed, and food cooks onto it, and that is where the smell is coming from.
Posted on Oct 20, 2009
  • 949 Answers
SOURCE: quiet partner 1 top rack does not get clean at all
I would suspect you have debris in the pump that is causing a pressure drop so the water is not spraying well in the upper arm.
Try this procedure to clean out the sump. Let me know if it helps.
Posted on Apr 25, 2010
Testimonial: "Very helpful, the link with step by step instructions was fabulous!!! Thank you so much, I was almost ready to go buy a new dishwasher."
My dishwasher the maytag quiet series 300, will not respond to the start button
Find your circuit breaker for your dishwasher and turn it off for 3-5 minutes. Turn it back on, then turn on your dishwasher. If this works, after the complete cycle of your dishwasher, you have to turn it off manually by pressing "on" botton then press it 1 more time to cancel; this will turn off. The defect is, probably the moisture built up in the control board causing it to ground some of the connections. Suggestion for the manufacturer, insulate the control board to prevent absorbing moisture.
Jan 04, 2013 | Maytag Dishwashers
Dishwasher won't drain--Maytag Quiet Series 300
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
May 13, 2010 | Maytag MDB8751BWQ 24 in. Built-in...
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Mar 22, 2010 | Maytag MDB8751BWQ 24 in. Built-in...
Maytag Quiet Series 300 won't drain all the way. I've checked the drain tubing and there is no blockage. Can someone help?
When you say you checked the drain hose, was top and bottom meaning did you pull out d/w. If you hadn't remove the bottom hose and check the bottom of the hose as well as outlets for the pump, clean out and run through cycle. If you had, then clean out the drain area in the tub of d/w. , should this not work, your pump is not working properly.
Oct 14, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Foul smell coming from Maytag Quiet Series 300
Hello jscott,
It is typical nowdays for most dishwashers not to drain all water out of the bottom tub (Even where you cant see) due to siphon design and energy efficiency. Try using about a liter of vinegar and throw it on the bottom tub of the dishwasher. Let it run through a full cycle and see how that works. Has worked for me
Sep 07, 2009 | Dishwashers
Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Dec 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
Water does not drain completely, mostly but not completely and just stays there Maytag Quiet Series 100
If the machine has a auto sensor or auto clean cycle it is supposed to keep water in the bottom. The sensor has to stay wet for it to work properly. My Maytag drains, then fills slightly to do this.
Jul 03, 2008 | Maytag Dishwashers
Maytag Dishwasher Quiet Series 200
The 3 symbol on the face control panel light is on and starts flashing anytime you push any other button, and is full of water in the bottom of it. My wife says she stopped the washing cycle a couple of days ago but now it wont start back up.
This is a Maytag series 200
Mar 15, 2008 | Dishwashers
Feb 15, 2008 | Dishwashers
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
1,152 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
