I have a HP F380 printer and I am trying to scan but when pressing the scan button the power button just flashes. I cannot locate the instructions.
  • 3wargo Nov 07, 2008
    when i had first tried to scan it appeared to scan but i could not find where on my computer it had stored the file. so i gave up for a long while in trying. now when i try to scan the power button just blinks.
    Master:
    Sergeant:
  • 461 Answers
You may not install the driver correctly, please make sure you install the driver according to your OS system. You may want to read below link for more information
http://etech.maiila.com/hp-deskjet-f380-driver-manual-and-software-download-including-for-vista
Hope this helps
Posted on Nov 07, 2008
My hp deskjet f380 is not scanning.
To scan, you need the HP Photosmart software installed (you can download it from HP at the link below). Start HP Photosmart, then put your original in the scanner and press the "Scan" button. You can scan multiple sheets, when you're done, click "done" and the files will be saved as JPEGs in the My Scans folder in My Documents.
Apr 14, 2011 | HP DeskJet F380 All-In-One Printer
How do i scan using a HP desktop F380
Deskjet F380 features a scanner within the upper portion of the device. "Scanning" an item describes the electronic process of converting pictures or text to data, then transferring that data to the computer as an image. Scanning an item into the computer is a simple task with the F380, the only limitation is the size of the item,
follow the steps below
Step 1
Turn the unit on by pressing the "On" button located at the top control panel. The control panel is located on the left side of the unit. The "On" button will illuminate to indicate that the unit is receiving power.
  • Step 2 Load the scanner with the item to be scanned. First, lift the lid of the F380 to the upright position to reveal the scanning surface. Place the item to be scanned face down onto the scanning surface. Position the item so that the edge of the item rests squarely against the front left-hand corner of the scanning surface, then close the unit's lid.
  • Step 3 Press the "Scan" button located at the lower left-hand corner of the F350's control panel to start the scan. If necessary, the scanning process can be stopped by pressing the "Cancel" button located just to the left of the "X" on the control panel.
  • Step 4 Save the scanned image to the computer when the scan is complete by clicking the "Accept" button on the window that appears on the computer's monitor.
  • Dec 29, 2009 | HP DeskJet F380 All-In-One Printer
    When i press the scanner button, it does not work, the power button starts flashing right after i press "scan" other then that, the copier and printer work, can someone please help me?
    have you installed printer software in your system and you connected the printer to system ( after connect the printer to your system press the scan button it will scan the document to your system ) all printer software like hp photo smart hp solution center ........
    now try and post your problem ...........
    Dec 17, 2009 | HP DeskJet F380 All-In-One Printer
    Non transfer scan to pc
    cd reader hp printer deskjet f 360 to be work
    Feb 05, 2009 | HP DeskJet F380 All-In-One Printer
    Hp deskjet f380 print and scan function copys with a wide black
    clean the print heads and run clean cartridge utility from printer properties window.after that
    disconnect the power and usb cable from the back of the printer and press and hold down the
    power button for 30 sec and then reconnect the cables and try again...open the backdoor and
    try to move the rollers in upward direction.
    Nov 26, 2008 | HP DeskJet F380 All-In-One Printer
    405 people viewed this question
    k24674
    jasbo
    jasbo
