I AM GETTING AN ERROR MESSAGE "PROTECTOR" FROM MY SONY HOME AMP
  • jhodgesatmb Dec 07, 2008
    I have a Sony STR DA333ES. We had DirectTV installed on Friday. Before that I had never had any issues with the amp. Now DVDs will play for a minute or so and then the amp goes into a flashing "protector" mode. Other replies suggested checking the speaker connections, which I will do since that does make sense and is highly possible given how gentle the DirectTV guy was with my system.
  • Anonymous May 04, 2009
    sony fm stereo receiver STR DE825.
  • 4,234 Answers
This indicates that a problem was found in the final output section of the amp. Usually this means that the output transistors have failed. If you can post the model number, I can provide you with additional details and cost extimates for repair.
Thanks,
Dan
Posted on Nov 07, 2008
Why did amp indicate error and turn off?
SONY ' eSupport - PROTECT or PROTECTOR is flashing in ...
https://us.en.kb.sony.com/.../protect-or-protector-is-flashing-in-the-displa...
Aug 15, 2015 - Turn off the home audio device, and remove all speaker wires from ... If a cord is frayed or in contact with another terminal, an error will occur.
How to get my receiver to stop flashing protected - Sony's ...
https://community.sony.com/t5/Home...to...receiver...stop.../182577
Sep 15, 2013 - intermittent video ... How to get my receiver to stop flashing protected ... is below the rated impedance range indicated on the rear of the home audio ... D.If the home audio device still displays a PROTECT error or does not turn ...
My AV receiver says OVERLOAD and shuts off, what should ...
Dec 26, 2015 | Pioneer Audio Players & Recorders
Sony dz 260 sd detect
I have the same message "SD Detect" when I press (together) Eject, Forward & Function buttons after message "Push Power Protector"...
Does anyone fix it already and can share what is the solution ?
Please contact with me: dziekan_tek(at)o2.pl
Jan 29, 2014 | Sony DAV-DZ260 Theater System
SONY Push Power Protector DAV - DZ610
Shahid, my Sony DAV-576WF is getting push power protector (SD detect), think it might be one channel blown, I do have the Schematic Diagram (service manu book) and ee knowledge with tool, could you give me a hand on fixing that when you got time?
It is no a fancy receiver but it does play SACD/DSD, that's the part I like
my email is yuyi429@hotmail.com
Nov 07, 2011 | Audio Players & Recorders
When playing DVD, it's sometimes display 'PROTECT' and stop playing.
Check if you receive the error when playing any DVD in particular.
What happens when you take out the DVD and try playing it again? Does it play
This protector error denotes several possible problems. Heat, volume level and incorrect DVD settings may be the cause of the problem. The following steps will help you correct your problem and rid your amp of its "Protector" error.
  • Examine your volume setting to be certain that your volume knob is not at maximum. Having your volume cranked too high can cause the capacitors to overheat, shutting down the receiver.
  • Unplug your receiver and disconnect your speakers from the terminals on the back. This will allow you to determine if the error is internal. Plug your receiver back in and look for the same error message. If you continue to get the protector error without having your speakers connected, you may have an internal electrical problem. In this case, contact Sony about finding a repair center.
  • Reconnect your speakers one at a time. The order of connection doesn't matter. When reconnecting, be sure that you do not have your positive and negative speaker wires crossed in any way. After each connection, test your amp by running it with a source. Give each speaker a few minutes of power before connecting the next one. This will help you isolate which speaker terminal is causing the error. When the protector error returns, take note of which speaker connection caused it. Check this speaker wire for shorts or torn shielding.
  • Examine your ohm rating of your speakers if you have no shorts or wiring issues. Sony receivers are not compatible with speakers lower than 4 ohms. Connecting a lower ohm-rated speaker will cause an error.
  • Turn off the surround sound option if you have both your A and B position speakers in use.
  • Keep your receiver well ventilated. Overheating due to poor ventilation can also cause Protector errors.
  • Examine the sampling frequency of your connected DVD player. If the error only occurs when you watch a DVD, the sampling frequency of the DVD player may be set too high. Check the sampling rating in your receiver's manual and in the DVD player
Mar 22, 2011 | Sony DAV-S500 System
I have sony ericsson W100i mobile. Whenever I try to send a message it displays a message " Out of memory delete messages?" However at that instant there are hardly any messages in my inbox, send...
dude this mobile is just a scrap..
i am suffering from day 1 since i have bought this cell phone. There s no solution to this problems. i even installed new OS and S/W from Sony Ericcson service centre. It didn't serve the cause. I am planning to contact directly the manufacturers to get my money back. If u guys have any idea how to do this then pls do mail me to this ID roshanzameer.21@gmail.com r call me at 8867790191
Jan 16, 2011 | Lexerd - SonyEricsson Spiro W100 W100i...
Protector Power Off Message
sounds like the stk is faulty,replace it
Aug 01, 2009 | Audio Players & Recorders
Power protector on sony surround sound system
Power protect is an error message that some thing is wrong in your sound system and requires qualified tech.
Normally that error message appears when unit got problem in amplifier output section, either it is speaker problem or some output chip is fried.
Feb 25, 2009 | Sony DAV-S400 System
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
301 people viewed this question
 Grubhead
Grubhead
