Monitor goes dull - Computers & Internet
  • mckay8 Nov 07, 2008
    digimate monitor for pc goes dull
Turned it off and on a few times [monitor] so far so good.
thanks for your help
Posted on Nov 07, 2008
Dull display on the monitor
Hi friend, In this case I would like you to please try and connect any other monitor to the system and check if you have the same dull screen in the other one.
If it has the dull display too then I would recommend you to please update the video drivers for the system.
If the display is fie on the other one, then I believe the life of the CRT tube of the monitor has ended and there is a need to buy a new monitor
Dec 13, 2010 | LG Studioworks 57M Monitor
My dell laptop thw screen flickers and even goes black some times untill u put pressure on the back of it and then thats only a temeprary fix till it goes bacck to being dull , flickering or black can i...
You may have loose connection between the LCD panel and the chassis, loose connection on the backlight board, you need to open it up and see, try reading about laptop repair here: <a href="http://www.insidemylaptop.com">www.insidemylaptop.com</a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Aug 25, 2010 | Dell E173FP 17" LCD Monitor
Aus monitor is dull and yellowish tint
You are missing Blue signal, check the VGA cable and all the pins at both ends, try it on another PC also.
http://www.badcaps.net
Jun 18, 2010 | Acer 19" LCD Monitor
HP F1703 Screen goes black within seconds of startup
That is either the backlight or its power supply.
This is a bit tricky as you can get it fixed under warrenty but they will likely ask you to send back the entire computer not just the monitor. It is also something that you could fix or several shops could but the repair cost really isn't much less than a new monitor. You are not stuck using an HP monitor so anything will work and you can get quite a lot bigger or better for about $120 and up. Repair cost is going to be $80-$100 so as you can see for just a few dollars more you have a new warrentied monitor.
Apr 27, 2010 | HP Pavilion F1703 17" LCD Monitor
I have a mw monitor ,it comes on for about a miniute then goes black i can hear sound . the picture is dull switch off then on same problem. can it be the backlight?
The picture board of your monitor has developed fault. That is why the screen goes black.
The best thing for you to do is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix on your own in other not to complicate issues.
The repairer will help replace the faulty picture board and your monitor is back and better.
Take care.
Apr 21, 2010 | EMC LCD Display mw Monitor
LCD is dull....
Try to connect the machine to an external monitor and see if display is ok or not.
Also, try updating the video driver and check whether you have connected the LCD correctly to the laptop.
Jun 04, 2009 | Dell Inspiron 2200 Notebook
Iiyama Pro Lite E485S
do exactly this:
- power off monitor with the POWER button!
- unplug power cord
- hold -/+ and keep holding them when briefly pressing POWER to get the monitor back on
- press menu
You are now in the service menu. Adjust the settings as you like.
- press EXIT
- power off monitor with button
- power on monitor with button
- AUTO SETUP... will be performed
- re-adjust brightness/contrast
Done!
edwin (rdam nl)
Apr 16, 2008 | iiyama Pro Lite 38a Monitor
Please help
Well, Declan try go to your display properties by right click on your desktop then left click properties. Go to settings tab and click the troubleshoot button.
Im afraid to say this however, its possible the your monitor has a problem because most laptops and as well LCD's and Flat Screen TV's have its disadvantage of its lifespan. Since these types of screens have limited feature especially on display that it doesn't distribute the light image very well inspite of its low radiation to give our visual taste more better and more clear. That's why that most of these types of monitors won't get your eyes strained. But when it comes to durability, it much lesser advantage to compare with CRT monitors.
Jan 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
Dell computer screen blacked out
Hello Sir,
Can you see any dull image on the screen, if yes, then The problem is with the inverter board in the LCD Screen,
Regards,
Aby
Dec 21, 2007 | AOC LM729 17" LCD Monitor
Philips LCD Monitor 150s3
The LCD display needs to be replaced. It has kind-of-a dull yellow tint. I guess you tried changing the brightness, contrast, etc.
Jun 27, 2007 | Philips 150S3 (Black) 15 in. Flat Panel...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
