Question about Fujitsu DL5600 Matrix Printer
Problem with fujitsu DL5600 " left end alarm"
I have problem with dl5600. it shows on display left end alarm and i can t do nothing. please help
  • Mik Does Oct 16, 2006
    message "left end alarm" shows every time i turn on the printer. when i turn it on fan starts and when the printhead must move then it starts orange blinking with display sign"left end alarm".
    Novelist:
  • 114 Answers
This error appears to be cause by an incorrect left margin offset. Page 3-15 of the user manual suggests possible work arounds. http://www.fujitsu.com/us/services/computing/peripherals/printers/discontinued/tmpl_models_dl5600.html Other than that, unfortunately Table 3-9 on page 3-31 says to contact a maintenance personel.
Posted on Oct 16, 2006
Backside Optical alarm (G) when using Duplex option
Hi Rasha,
ADF backside scanning optical alarm (upper optical unit ADF) is E3 alarm. When there is an irregularity in the amount of light (ADF back), "E" and "3" will be displayed alternately on the function number display panel of the scanner.
Please check the followings:
1.Does the same symptom occur after turning OFF and ON the scanner?
2. Is the lower glass (white sheet guide) of the reading section dirty? Open the ADF, and clean the sheet guide (white part) and the glass.
3. Is the upper Optical unit ADF dirty? Are the cables damaged? Are the connectors connected properly?
4.E3: Is the upper lamp ON? Are the cables damaged? Are the connectors connected properly? Disconnect the SCSI cable and turn the scanner ON. Open the ADF and press ADF cover open sensor as shown below to see if the ADF lamps light which has to be replaced.
I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 12, 2013 | Fujitsu fi-4750C Flatbed Scanner
Fujitsu plasma vision monitor. Pds42211 red flash 5 times, long number displayed lhs.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
There is details about the blinking codes to Fujitsu Plasma Display.
Oct 31, 2012 | Fujitsu Plasmavision PDS-4221 42 in....
Set alarm on rm826
Hello
Press the DATE/ALARM key once to show the alarm time.
The ((.)) icon is displayed in the lower left portion of the screen to alert you that the display is showing the alarm time. To return to the month and date display, press the DATE/ALARM key once.
Nov 17, 2011 | Oregon Scientific RM826 Exactset Travel...
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Fujitsu scanner light bar will not return to
When you face such errors, please check if the Scanner panel displays-"E-0" and TWAIN displays- “The running system is abnormal. Please confirm the carrier lock has come off.”
The error is Carrier unit drive alarm. After power-on, carrier unit (FB) moves to home position, that is where the carrier unit locates when home position sensor is turned ON. If the home position sensor is not turned ON after the carrier unit has moved pre-defined steps, this error occurs.
Probable causes:
Defective sensor, motor, or carrier belt.
Also, please check the following:
1. Is there is any abnormal noise from FB motor when this error occurs?
2. Does any foreign object get inside drive unit or carrier unit?
3. Is CR belt tension loose? Loose belt should be tightened.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Mar 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
I have lost the operating manual for a technika DAB 109 Radio
I HAS SAME PROBLEM BUT FOUND THE ANSWER. PRESS STANDBY AND TURN UNIT ON, THEN PRESS ALARM BUTTON, DISPLAY SHOWS ALARM 1, PRESS SELECT BUTTON DISPLAY SHOWS FM/DAB/BUZZ, PRESS LEFT/RIGHT BUTTONS TO SWITCH BETWEEN WAKE UP OPTIONS, THEN PRESS SELECT AGAIN, DISPLAY SHOWS OFF, PRESS LEFT/RIGHT BUTTON TO TOGGLE BETWEEN ON/OFF LEAVE 'ON' SHOWING, PRESS SELECT AGAIN DISPLAY WILL SHOW ALARM TIME, USE LEFT/RIGHT TO SET HOUR THEN PRERSS SELECT, USE LEFT/RIGHT TO SET MINUTES TEHM PRESS SELECT AGAIN, DISPLAY WILL NOW SHOW SMALL ALARM CLOCK IN DISPLAY WINDOW, THIS MEANS ALARM IS NOW SET.
Mar 07, 2010 | Audio Players & Recorders
My fujitsu dont start vga
When you power up the computer press F8 key then enter in enable vga mode then go to start ->control panel ->display ->settings .
Change screen resolution to 1024*768.
Then apply and ok.
But if you are not able to see any display so you need to refix RAM memory if you are able to enter in safe mode or enable vga mode then there is only issue with graphic driver.
Let me know if you need more assistance.
Thanks.
Oct 22, 2009 | Fujitsu Siemens SCENIC P300 PC Desktop
Front side optical Alarm
Contaminates on the optical path to the front camera.strip and clean.If its still a problem , check and replace front lamp.(the one in the flatbed area)
Jul 04, 2009 | Fujitsu M4097D IPC Path-Through Flatbed...
Flashing red light no screen fujitsu plasma
This is a common complaint with Fujitsu plasma displays with a few years age. It is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
Jun 04, 2009 | Fujitsu Plasmavision 42" TV
Scanner Display Shows False Jam
You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 15, 2008 | Fujitsu fi-5750C Flatbed Scanner
114 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Vincent_G
Vincent_G
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
