Back to:
Tags:
HP UPS System
UPS 1800VA
posted by Xemi on Oct 16, 2006
I want to change bateries in my UPS HP A2997A 1800 VA. Is it possible to change these bateries with 5x12V bateries and 55 Ah(car bateries.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 16, 2006
FixYa! (100)
Nightdiver
Rank:Guru Guru
Rating: 88%, 150 votes
You can go here to replace these batteries:
http://www.batteryspec.com/ecomm/cart.cg...
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on UPS 1800VA:
I don't want to Accept this solution
Solution #2
Thanks for Trying (70)
dugiehowsa
Rank:Wiz Wiz
Rating: 78%, 759 votes
Unfortunately not. The batteries for UPS's are made exactly for each model, not only in voltage and amperage ratings, but also to fit in the UPS casing.
Thank You!
Solution #3
posted on Apr 10, 2007
Not Rated (0)
pipeguy
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
You can increase the capacity of the batteries from the original equipment, but you cannot put more load onto the UPS. Your runtime may be increased, but you may have trouble fitting the car batteries into the case. Some UPS's have external connectors for external battery packs. Find one of those and add the batteries to it. Make sure that you maintain the DC voltage which the UPS requires. It may be 12 volts or 24volts. Two 12 volt batteries in Series.
Thank You!
Can you Help with these UPS Systems Devices problems?
UPS Systems Devices
My daughter has the above referenced Leap Frog toy. I am a...
UPS Systems Devices
Hi Cluny Brown You have answered a question similar to...
UPS Systems Devices
I have a Titan UPS which had blown a 1N4937 fast recovery...
UPS Systems Devices
external harddrive keeps coming up as a device on your...
HP (A2997A#002#017) UPS System
ICAN'T FIND DRIVER FOR HP POWERWISE L600 MODEL C4777A
Loading problems.
Repair Service
Find UPS Systems Device Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
