Question about Ricoh Aficio 250 Copier
Ricoh nrg mp 1600 Aficio copier/scanner/printer
I am Susan from Kenya,i have a problem with scanning because my machine can only connect with only 2 computers for scanning but printing and photocopy is ok.
Kindly provide a solution.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you have all of those features installed on your computer?
  • Tim Babcock
    Make sure that desktop binder or scan router is installed on your computers.
    Windows Firewall should be turned off as well.
    Twain drivers should be installed on each computer you will be using for scanning.
MP 1600L copier/printer produces print-outs with small toner dots spread over the paper. How can I solve this problem?
Posted on Feb 27, 2009
    Problem Solver:
  • 9 Answers
I should think that your toner is contaminated with moisture particles minimalism in size, but enough for these dots to appear. In any event you will need to have the rollers cleaned.and change the toner. Do not use old toner, this will add to your woe.
Posted on Sep 14, 2012
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
How to adjust Heat in Ricoh Aficio MP 2000l2
what problem does it gives when photocopy machine get under light.it that true it give dark on the top of the paper
Jun 20, 2013 | Ricoh Aficio MP 1600 Black and White...
Gestetner Aficio MP 1600 was connected to my System and I use it as photocopier, scanner and printer. The machine's Drum was changed of recent and it has failed to scan any of my documents. However, I...
Hello!
Changing the Drum does not affect the scanner settings.
You can print because your PC (computer) can see your machine but for scanner is the oposit. The machine must see your PC.
I think that in this machine you have an SD card with the scanner funtion. Try to take it off and then put it on again. (the SD card is on its side. In the controller box)
If you still have any doubt reply to me.
Aug 01, 2011 | Ricoh Aficio 250 Copier
How we print a document on both sides (back and front) of the paper in RICOH Aficio MP 2000L copier
Hello!
If your machine have that option you just need to go to the printer properties and select the duplex.
If you have any doubt reply to me.
See you!
Jul 07, 2011 | Ricoh Aficio MP 1600 Black and White...
Ricoh aficio mp 1600 le scanner driver
pls advise scanner driver for window server 2003
Jun 10, 2011 | Ricoh Aficio MP 1600L Black and White...
We have a network ricoh aficio mp 1600 pcl printer we recently upgraded to windows 7 printer and copier are working ok but scanner is not working is there a problem with the scanner driver for windows 7
please go to www.ricoh.com and instal the scanner drivers of windows-7 other wise you can instal the scan to folder which dos not required any drivers or you can install scan to mail this also does not required any drivers - thanks
Mar 10, 2011 | Ricoh Aficio MP 1600L Black and White...
I have Richo Aficio MP 1600 all in one device-- Faxes fine, copies fine; Cannot get scanner to connect although Twain drivers are installed & device is connected to the network with its own IP address,...
Make sure the gateway is entered correctly, are you scanning to file or E-mail? Using web immage monitor is the easiest way to do it either way. if you have questions e-mail them to quennie@wcvt.com -Carl
Jul 07, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh Aficio 250 Copier Logo
2,165 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
