I require a 1G SD RAM UPGRADE FOR MY ACER TRAVELMATE 270 SERIES. CAN YOU HELP? Thanks, Lionel.
  • 116 Answers
Go to harvey norman and by a 1gig sd ram stick
Posted on Nov 07, 2008
Upgrade to higher cpu speed travelmate 270
CPU speed is not going to make much of a difference. You need to increase RAM (random access memory). This will make a huge difference in speed performance.
Aug 06, 2014 | Acer Computers & Internet
How to replace batteries in batterypack of travelmate 270?
http://www.battdepot.com/us/model/Acer/TravelMate+270.aspx?gclid=CJD2oLTw_L8CFQmoaQodn2EAQw
Aug 05, 2014 | Acer TravelMate 270 Laptop Charger...
I just can't find the audio and video drivers for a acer travelmate 272, can you help me?
The travelmate 270 series should include your laptop, drivers are available at
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=195
if you need further assistance please let me know before giving feedback.
Thanks,
Ekse
Feb 22, 2011 | Acer TravelMate 272XC Notebook
Hi there: i install win 7 but my travelmate 2480 has a very low speed what can i do. thanks
purchase a new ddr /ram for ur laptop,,defrag hdd,,do disk cleanup..also windows 7 u can if u have a multi sd/card rder,,put one in,,go under properties,,use ready boost makes a sd card wrk like ram,,makes it fasters also
Nov 01, 2010 | Acer TravelMate 2480 Notebook
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
Mar 22, 2008 | Acer TravelMate 2702WLMi Notebook
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Memory
The compatible ram for your travelmate 270 ram is 256MB PC-133 SDRAM DIMM Memory Module.
This information can be found on Acer website.
If this solves your problem, please mark this as Solved.
Thank you
Oct 12, 2007 | Computers & Internet
Upgrade RAM
hi, to upgrade your laptop's memory here's the info you need to order the new module or modules http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?id=1&SysID=25068&mfr=Acer&model=TravelMate+2410+Series+2413%2C+2418%2C+2419&root=&LinkBack=&Sys=25068-Acer-TravelMate+2410+Series+2413%2C+2418%2C+2419&distributor=0&submit1=Search regards
Aug 18, 2007 | Acer TravelMate 2413LMi Notebook
Dismantle Acer travelmate 270 Laptop
Caution is advised, as getting everything to work again after you put it back together is normally difficult, especially the screen. You will have to remove all the panels underneath, all screws and look for screws around the screen hinge area, with hexagon heads. There are no instructions on acer notebooks on their site for obvious reasons.
Mar 18, 2007 | Acer TravelMate 270XV Notebook
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
