Symbol Batch Barcode Scanner CS1504 Keychain Scanner CS 1504 Synch Software
Problem for Symbol Batch Barcode Scanner CS1504 Keychain Scanner CS...
My XP Media Center PC does not recognise the scanner
By CarlMoss on Oct 16, 2006
When plugging in the USB cable the scanner green LED flashes briefly but the PC just does not flinch - it does not recognise the thing at all. Also tried plugging it in via the serial connector. It came with a Serial cable and serial to usb converter. I also tried connecting it with my blackberry usb cable which has the same connector at the other end. Again nada. Any ideas welcomed. Carl
Comments:
Oct 17, 2006
- Hi, yes it is a thought - USB ports seem to be very temperamental - some days they work with some devices - other days I have to swap them around. Anyhow, I tried your suggestion and another USB port recognised something when I plugged the scanner in - in Windows explorer 4 devices showed up at once - all one kind of disk drive or other - clicking on each in turn however all ended in the message "insert disk into drive XYZ". So, what next? Should I try working on the Serial connection - how does that work? Thanks in advance, Carl
Best Solution
posted on Jan 03, 2007
Helpful)
Panstis
Rank: Apprentice
Rating: 85%, 4 votes
this scanner may not be supported in XP. I have been using this scanner for a couple of years on my pc and now I have upgraded to XP and it wont work. the driver is not supported! I am looking for a newer driver that is supported by XP
Was this helpful?
Yes
No
Solution #2
posted on Oct 16, 2006
Somewhat Helpful)
dugiehowsa
Rank: Wiz
Rating: 77%, 871 votes
Your USB ports on your computer may be bad. Do other devices work if you plus them into the same USB port?
You can try plugging the scanner into another PC with USB ports. If it works in the other PC, then that points to the original PC's USB ports. You can try buying an add-on USB port or using other USB ports on the PC.
If it still does not work, then there may be a problem with the USB port on the scanner, and the scanner itself may need to be serviced.
Was this helpful?
Yes
No
Popular Solutions for Symbol Batch Barcode Scanner
Questions and Unsolved Problems for Symbol Batch Barcode Scanner
Do you recommend Symbol Batch Barcode Scanner CS1504 Keychain Scanner CS 1504 Synch Software?
Answer
Answer
My SVP FS-1000 does not scan with the color or clarity of the original color slide. Yellows are... (More)
Answer
i have an hp photosmart c4200 all in one and it will let me do everything but scan i need... (More)
Answer
scanner fell off the top of the pc system unit onto the carpeted floor - maybe 15 inches. now wont... (More)
Answer
Date and Time stamp function goes out and shows a 63 as seconds or minutes. Is there a fix for this?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Symbol Batch Barcode Scanner...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
