Question about GE JKP45 Electric Double Oven
GE JKP45 double wall oven shuts off
Oven shuts off at higher temps.Panel goes dark, clock goes out, elements stop heating. Will stay on at around 200 degrees for hours on end. Turn it up over that, after a period of time it will shut off. Bottom seems to be more tolerant especially if top oven is opened for ventilation. Oddly enough my wife slapped the control panel and it came back on. Might have been coincedence though. Self cleaning function does the same, it gets to about 375-400 and shuts off. 20 minutes later after the oven cools down it comes back on. Any help??
Several months ago, my lower GE JKP45 oven started making funny noises and stopped working at the same time. The same thing happened to my top oven recently. I can still hear the funny noises unless I leave the door open. And if I close the door then the noise starts again and the door will lock itself and won't open for awhile before suddenly I am able to open it.
Posted on Mar 17, 2011
  • 166 Answers
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Posted on Nov 20, 2008
Ge model jkp45 top oven does not heat
Look for the problem in 3 places.
1) the element has burned out.
2) The connector where the element is connected to the wiring has failed, or
3) the wiring has burned in two.
God bless your efforts.
Oct 21, 2017 | GE Ovens
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Neither oven will heat when start is pressed, get a clicking sound from panel, temp stays at 100 deg.
Check for 220v as 110v will give one leg of power but not both. your breaker. or your control board is faulty.
Sep 03, 2012 | GE JKP45 Electric Double Oven
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
Bake element doesn't heat, broil does. When I turn on pad, it goes to 100 but won't heat up
replace element. it is approx 19 dollars. 2 screws in back and then 2 screws holding element to wires. not a hard job
Nov 12, 2009 | GE JKP45 Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Heating element
the chances are the top oven thermostat has gone and may need replacing. also check on any selector switches relating to the top oven unit they can burn out on the contacts. there is no seperate fuse.
Jan 20, 2008 | GE JKP45 Electric Double Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
GE JKP45 Electric Double Oven Logo
343 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
