Question about Durabrand DWT1304 13" TV
Unwanted rectangular black area appears on screen blocking 40% of picture
Sometimes a large black rectangular area appears on screen and will go away for a few seconds if I push the volume up or volume down button. Turning off the TV for a few seconds doesn't seem to change anything, but turning the TV off for several minutes usually makes the prolbem go away. Any suggestions?
  • Paul Lam Nov 07, 2008
    Sorry, but I don't think a shorted yoke could produce this symptom. The symptom is not a diagonal line, but is a large, completely filled-in black rectangle that occupied approximately 40% of the screen area. the black area dies not extend to either side, nor to the top or the bottom of the screen, and is mostly in the bottom half of the screen.
    Sergeant:
  • 280 Answers
This could be the result of a partly shorted vertical winding on the deflection yoak.Since the line is on an angle and not straight across.
Posted on Nov 07, 2008
  • coyotedave Nov 07, 2008
    Make sure closed cap is turn off..
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
How to clear a square on tv screen that has a black rectangular block in middle of picture?
it could be you have pressed the old teletext service button, look for a button with 3 lines on it in a box and press it or try turning the tv off at the plug then back on again.
Jan 22, 2015 | Televison & Video
Black Square area on Screen
If you press display on the remote, it will go away. It will come back, it's a common fault for this set and theres a mod to be done to the eeprom.
Apr 24, 2009 | JVC AV-32120 32" TV
I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
Jan 11, 2009 | LG 42PB4D 42 in. Plasma HDTV
Large black square blocks screen
Most likely it's the closed captioning has been turned on. From your post I assume you have the remote control and able to access the menus so try to turn off the closed captioning. I'll be notified if you post something new.
Nov 27, 2008 | Toshiba 32A33 32" TV
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Nov 03, 2008 | RCA F32650 32" TV
Rectangular Black Box Covers Lower Half of the Screen
I found this because I"m having the EXACT same problem with my DVD. Very frustrating that nothing works....
Feb 10, 2008 | Sony DAV-C450 System
A black box appears on the screen
Just happened to see your black box problem associated with your T.V.; Thought I would pass along an idea for you to check into, and let me know if it helped...Check into whether or not it has a onscreen text block mode, if it gets into this mode by accidentally pressing the wrong buttons on the remote and or TV, it could and I have seen, at least with zeniths, a big black box which will cover the whole screen except for a 2 to 4 inch border around the box and outer edge of the screen...if this is the case, find someone familiar with the correct setting for the set associated with this problem, and get it back into the right mode....Hope this helps..T.
Jan 15, 2008 | Haier 20" TV/DVD Combo
Solid black rectangular area at the center of the screen
try checking the captions button, labeled CC.....or in menu under captions. It must be turned on or is in text1 mode
Nov 19, 2007 | Zenith B19A02D 19" TV
Durabrand DWT1304 13" TV Logo
120 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
