Question about Lanzar VIBE241 Car Audio Amplifier
Lanza vibe I have had a lanzar vibe 251 amplifier fitted to 2x 12inch pioneer subs ts-w307d4 installed. What cross over settings should i set on the amplifier to get deep rolling bass instead of the hard solid bass i'm getting now. I also have a corssover linking my two amplifiers.
  • Wayne Bayley May 11, 2010
    Check on the side of your amplifier and tell me if it has a Sub Sonic filter adjustment?
    Problem Solver:
  • 8 Answers
You would want it on low not full or high bkz your system is not set up for full or high
Posted on Jul 25, 2010
What amp to use for two pioneer ts-w307d4 car subwoofers
Just get 2pi amp pros at1200 watts. That way u have full control of the bass u need. Just remember to turn the amps down the subs are a little under rated. Done this myself and it is a great sous. There not a good pro sub but they will do the job in a mid size car
Jan 30, 2012 | Pioneer TS-W307D4 Car Subwoofer
I have a ts-w307d4 pioneer sub woofer and its a 4 ohm sub that has 4 terminals on it 2 red and 2 black how do i wire this sub to my amp i have a sony 1200 watts stereo amp and my sub is a dual voice coil...
conect one of the positive terminal from the sub directli to one chanel of the amp, and do the same with the negative,and do the same with the others terminals from the sub conect to the other chanel
Aug 12, 2010 | Pioneer TS-W307D4 Car Subwoofer
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Output problem
dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
I have the pioneer sub and a sony 600watt 4
it has a detector that kicks in it will usually shut off your amp and it keeps you from blowing your amp the speaker may have to much power and amp may not push it it will start to protect itself
Jun 07, 2009 | Pioneer TS-W307D4 Car Subwoofer
How do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Mar 10, 2009 | Pioneer TS-W307D4 Car Subwoofer
Help with ts-w307d4
the money to fix will be better put to some new ones.
Mar 01, 2009 | Pioneer TS-W307D4 Car Subwoofer
Recommended vented box volume for tx-w307d4
pioneers are subs u have to be careful with, some subs are made for ported boxes and some arent, check if it is, tham if it is it should b tuned to about 35hz-45hz.
Nov 28, 2008 | Pioneer TS-W307D4 Car Subwoofer
2 Subs running together
If they have the same impedence (like 4 ohm) then you should be able to run two different model number speakers as if they were the same model number. There might be a slight difference in the way they sound, but I would not expect it to be enough to be noticeable. Good luck.
Mar 27, 2008 | Pioneer TS-W301R Car Subwoofer
My subwoofer will not go
Is the SUB connected to both channels? I will give you detailed instructions on how to connect a sub. Check out this website.
http://www.ehow.com/how_5829_wire-car-stereo.html
Mar 03, 2008 | Pioneer TS-W307D4 Car Subwoofer
Lanzar VIBE241 Car Audio Amplifier Logo
82 people viewed this question
Top Lanzar Car Audio & Video Experts
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Jose Velazquez
Jose Velazquez
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
