Question about Panasonic Palmcorder PV-DV53 Mini DV Digital Camcorder
Panasonic PV-DV53D When I had recenetly charged my battery and replaced it in my camera my camera was working properly but the red light for power was blinking. I tried to play or rewind my tape and it did not work but the red light kept flashing. Eventually the camera shuts itself off. I thought the battery was not charged properly so I charged it for another day then tried again but still my tape won't do anything. I switched taped thinking it was a tape error but it did the same thing to a new tape as well. I checked the parts inside to see any visible broken pieces that feed the tape but saw no problems. What should I do to fix this? Please help...
  • 5 more comments
  • Aubreykay Nov 05, 2007
    Has anyone figured out how to solve this problem? I have a black screen when I turn the camera on and my power light is flashing. I have no controls as far as play/rewind/fastforward and limited control in the menu...sometimes it will let me, sometimes it won't. I can record sound, but no picture. It will shut itself completely off after a little while. Any ideas?
  • tonya0854 Dec 08, 2007
    the red light blinks when I insert a tape. It eats the tape if I try to play it in vcr mode. The red light blinks in camera mode, almost as if to let me know it has shut down due to some tape defect. I tried a head cleaner tape and it ate that up too.
  • mobrij Dec 12, 2007
    When I had recenetly charged my battery and replaced it in my camera my camera was working properly but the red light for power was blinking. I tried to play or rewind my tape and it did not work but the red light kept flashing. The same goes for recording. Eventually the camera shuts itself off. I thought the battery was not charged properly so I charged it for another day then tried again but still my tape won't do anything. I switched taped thinking it was a tape error but it did the same thing to a new tape as well. I checked the parts inside to see any visible broken pieces that feed the tape but saw no problems. What should I do to fix this? Please help...
  • Anonymous Jul 22, 2008
    I got the same problem.I bought this camcorder from my friendw who swore up and down that it could be fixed by local electronic repair shop for 30 $.
    Heck I only payed $5 for it so i was wonderingif any reputable online repair shops would do the fix and what would it cost?
    Thanks
  • Anonymous Dec 15, 2008
    I have had this same problem off and on for a few years. I even sent it back under warranty and Panasonic replaced the tape drive mechanism.
    The menu reset option didn't work for me, but Solution #10 (putting the tape in while it is 'on' and pressing the record button, did the trick. I have no idea why it worked, but it did.
  • dginyard14 Jan 03, 2009
    I was experiencing the same problem. Labber's solution worked for me. I had to redo the steps several times but it finally worked :)
  • Anonymous Mar 21, 2014
    Camcorder recorded ok . After charging battery red light flashed indicating it was charging then stopped. When finished but camera will not turn on. Can you help please?
I was having the same problem. here's the solution that worked for me - should do it for you as long as your camera stays on long enough. 1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in. 2. press the menu button (near the viewfinder) 3. Use he wheel on top next to the viewfinderto scroll through the choices 4. Choose "display setup" by pushing the wheel in 5. Choose "C. Rest" by pushing the wheel in 6. Turn camera off 7. Next time you turn camera on you should be able to view tapes and record. hope that helps!
Posted on Nov 01, 2006
I have the same palmcorder, model DV53D and have had the blinking red light problem 2 different times. The first time I was able to use the menu reset solution listed on this page and it worked. The second time it happened I had been recording with the palmcorder when the battery died. I took the battery off, recharged it, and put it back on but the timing of something was off and the blinking red light was back. I tried to reset a hundred different ways but nothing worked. I finally got some help from another online source that advised me to plug the unit into the ac adapter to make sure I was getting enough juice and to then try reseting from the menu and then putting in a brand new tape in camera mode. It worked.
Ultimately the blinking red light does have something to do with a tape being too tightly wound and I think the combo of using a new tape and the ac adapter got it working again. I was able to put the other tape back in and it's up and running again.
Posted on Jul 31, 2009
The answer to this issue is the fact that the tape is wound too tightly. The blinking red light is saying, "if I apply force to the tape that is not moving, either the tape pops, or the motor goes, if the tape is too tough" What I did, was remove the tape, flipped the lid back. Pulled some excess tape out. Took a palm stylus (or similar shaped stick) and held down the tab in the center of the back of the tape. I then took the erase end of a pencil, and began to turn the tape reel by hand. I then stopped, and stuck my stylus in the center hole (between the 2 spools) a few more times, to make sure it wasnt stuck any way. When I put the tape back in, I turned the power on and no more blinking.
Posted on Aug 28, 2008
  • y632 Aug 28, 2008
    the answer to this issue is the fact that the tape is wound too tightly. The blinking red light is saying, "if I apply force to the tape that is not moving, either the tape pops, or the motor goes, if the tape is too tough" What I did, was remove the tape, flipped the lid back. Pulled some excess tape out. Took a palm stylus (or similar shaped stick) and held down the tab in the center of the back of the tape. I then took the erase end of a pencil, and began to turn the tape reel by hand. I then stopped, and stuck my stylus in the center hole (between the 2 spools) a few more times, to make sure it wasnt stuck any way. When I put the tape back in, I turned the power on and no more blinking.
    Problem Solver:
  • 5 Answers
I tried the solutions and sadly they didnt work. So I have decided to use it as a webcam. does anyone know how to keep this camera from automaticaly shutting off. Thanks
Posted on Jul 02, 2010
I have had the same problem now three times. I bought a warranty through mack camera, and each time I sent it back they said they replaced the tape deck mechanism.
Posted on Jan 26, 2008
I have the same problem. I took mine apart and looked at the tape mechanism. Looks like one of the little motors are acting up. Works fine for a while. Then acts up again after 20 tape ejects or so then blinks it's red flashes of death. They must have went too cheap on the motors. If I figure out a cheap fix I'll post it for ya =/.
Posted on Feb 04, 2008
    Dedicated:
    Visited the website for 20 consecutive days.
    Passionate:
    Visited the website for 10 consecutive days.
  • 13 Answers
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
6. Turn camera off
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS LABBER
Posted on Jan 05, 2008
My camera did this like 3 years ago and I never did any research to fix it until now...going into the menu and resetting the display thing worked...yoiu just saved me 500 dollars...thanks a bunch
Posted on Dec 01, 2007
My wife's camera developed the same problem, and I tried the menu solution. It worked!! Thanks, all!
Gamma
Posted on Nov 15, 2007
I tried all this but the only thing worked was to remove the tape, leave cam ON and then put the tape back and turn recording on. It worked.
Posted on Jun 10, 2007
My pv-dv53 did the same thing. now it's fine i don't understand. seems like there may have been an unregistered dew problem. maybe it dried itself out? good luck
Posted on May 15, 2007
Mine was doing the same thing. It wouldn't play any tapes. I stuck my finger in the tape path and moved all the metal and rubber rollers to see if they were free, which they seemed to be. After I tried it again, it is working. I don't know if it will help, but it is worth a try. Panasonic wants $261 to repair it, which is more than some newer ones. Maybe you will get lucky too, otherwise it is just a paperweight.
Posted on Jan 22, 2007
The solution posted didn't work for me, I have the same problem. Did you find another one or did this one work for you?
Posted on Jan 19, 2007
I have a PV-IQ404 Panasonic Palmcorder that the power pack has been lost from. Can this be replaced?
By power pack do you mean the actual battery or the charger unit that plugs into the wall to charge or power your Palmcorder? Either way, bot are available on Ebay as universal units and you should make sure the charger or battery pack is for or a 6 volt capacity. Many chargers for these Palmcorders are labeled as VHS-C / 8MM, that should work with your camera. Universal battery packs are made reversable, meaning that you can flip the battery to accomodate several other camcorder models. I've replaced my batteries and charger for my Panasonic Palmcorder from Ebay.
Dec 06, 2014 | Energizer Panasonic Pv-iq404a Camcorder...
The power on the Panasonic Palmcorder IQ PV-A206 turns itself off. I've tried plugging directly and with a fully charged battery, no luck.
please make this test and fix it. God bless you
If the video camera doesn't work, make sure the battery is charged (see The Battery Recharger Fix-It Guide) or replace a battery that won't hold a charge. Make sure the AC adapter is connected properly. Clean any dirty contacts on the battery, charger, and AC adapter with a cotton swab dipped in denatured alcohol. Remove corrosion with a clean pencil eraser, then wipe the area with an artist's brush to remove any debris. Find and test the fuse, if any.
If the power goes off soon after starting, recharge a low battery. Also, turn the video camera power off, then turn it back on and eject the tape. If the problem persists, check the fuse
If the battery won't charge, clean the contacts and fully discharge the battery, then recharge it. If the problem persists, replace the battery
If the video camera works intermittently, remove and reseat the to establish good contact. If necessary replace the fuse
Nov 08, 2013 | Sharp Panasonic Palmcorder Iq Model...
My pv-gs180 camcorder wont power up. I have
Remove battery plug it into power (charger block) then do reset.
Oct 12, 2009 | Panasonic PV-GS180 Mini DV Digital...
No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Dec 12, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Flashing red power light
The problem here is condensation inside the camera. I leave the camera turned off, remove the cassette tape and then point a hair drier on warm or low heat and slow speed right into the innards of the camera through the open cassette tape door. I run the hair dryer for 5 minutes and then replace the cassette. If the camera still dosen't work just wait for another 5 or 10 minutes and then it will work OK.
Jan 26, 2008 | Panasonic Palmcorder PV-DV102 Mini DV...
Camcorder is not recording
the capstan motor of the camera is not running that why the power display is blinking and when you eject the tape there a portion of the ribbon that left..it is a poor connection of the capstan motor to the main board of the camera....
Dec 13, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic PV-GS19 Mini DV Digital wont turn on
I have about 2 dozen of these that my students use at my school and the power supplies are kept in a locked room only to be used by me. The reason? They get easily damaged. The little metal part that plugs into the back of camera is often the culprit. If the power supply/charger is pugged in and the metal tip at the other end touches anything metallic (keys, metal tripod, etc.), it will short out and render the unit useless. If the amber light doesn't go on on the charger, and you are sure you it properly connected to a power source, then my guess is that it's a damaged power supply. You can purchase a new one online at Panasonic Go to this link and click on the Parts locator link near the bottom of the page. http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportModel?storeId=15001&catalogId=13401&displayServiceCenter=false&displayPartsLocater=true&itemId=88739&catGroupId=25203&displayTab=A&surfModel=PV-GS19&surfCategory=Camcorders%20with%20SD
Jun 30, 2007 | Panasonic PV-GS19 Mini DV Digital...
Correct cable for downloading video to PC??
Hi there, you need the i.Link cable. Please check this link: http://catalog2.panasonic.com/webapp/wcs/stores/wwwconsumer/customersupport/FAQlisting.jsp?storeId=11251&itemId=63123&modelNo=PV-DV53 Best regards.
Apr 26, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Pv-dv53 not working? power light flashes
I've been having this some problem as well. Actually, I had the problem a year ago, spent almost sticker price to get the thing fixed, it worked for a while but I didn't use my camera much, and now the problem has returned.
Jan 19, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic Palmcorder PV-DV53 Mini DV Digital Camcorder Logo
1,687 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
