defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
The user lock code is usually the last 4 digits of your phone number. If that doesn't work, you can call your carriers customers service and request for the code. Just make sure that you already have your phone's IMEI as the operator might ask you for it. You can retrieve your phones IMEI by typing *#06# on your keypad.
1.Reset to the default settings: -From the carousel's Home tile, press the OK button for Menu -Select Settings -Select More (7) -Select Security (12) -Enter the User Lock Code (last 4 digits of phone number) -Select Erase/Reset (3) -Select Default Settings (0) -Press the left soft key for Yes to confirm -Press the left soft key for Yes again to confirm
2.Permanently delete all data and reset: -From the carousel's Home tile, press the OK button for Menu -Select Settings -Select More (7) -Select Security (12) -Enter the User Lock Code (last 4 digits of phone number) -Select Erase/Reset (3) -Select Reset Phone -Press the left soft key for OK to confirm -Press the left soft key for Yes -Press the left soft key for Yes again to confirm
After resetting your Samsung Reclaim M560, you will miss all data, so you should back up the necessary data first.
My phone started doing the same thing. I returned it to the store and the clerk actually tried to accuse me of dropping the phone.It has been two weeks in the shop --not sure yet what the problem was. (my phone is 8 months old)
