Question about Sony KP-61HS30 TV
Ghost PIcture Recently, my Sony KP-61HS30 Projection TV started to flicker in and out of picture. It would have a double image of red and green colors. After warming up it would go back to normal, but now the picture stays in the double image mode. What is causing this and is it worth fixing? Any help with this would be appreciated.
    President:
  • 3,130 Answers
Uniontrip, im afraid you have a problem some other 3 illion other rear tube projection set owners face or will face in the near future. Its called a convergence problem. You see there are Two IC's inside this set that correct the alighnment of the three picture tube alighnment to each other to get a steady straight picture. To fix this problem, both IC's should be replaced together as a whole, even if its only one IC bad now, you can bet your bottom dollar, down the road, the other will go bad as well. If you have any solid state repair experience and know how to unsolder and solder printed circuit boards, this is not really a difficult job to do, as they are two black IC's standing up against a metal heatsink and the lettering on them will start with STK###-###, the # being other numbers. Now since these are solid state sets and they really have noi USER replaceable parts inside them, it is always best for the non experienced to refer to a trained repair technician to do this sort of repair. Most of the time, a repair such as this, should not exceed a couple to a few hundred bucks. Good luck. Please do not forget to rate this thread.
Posted on Oct 16, 2006
How do i find out if sony kp/57ws510 picture tube is bad
While the set is prone to bad tubes a double or 3d like image is convergence--this model uses two of the STK-392-560 CHIPS for this.
Go into customer menu and call up convergence--if off and will not adjust in any area of the screen the chips are bad.
May 02, 2012 | Sony KP-57WS510 57" Rear Projection HDTV
Aproximately 50% of the Tv's image is distorted by a green and red doubled image. Can we fix this
Yes, this problem can be fixed if you are handy with electronics stuff repair and can solder parts in circuit board easily with proper tools.
Replace convergence out ICs to get converge picture.
Let me know exact model number and brand of your TV for further info as question shows its Sony KP-51HW40 tv.
Jan 08, 2010 | Sony KP-51HW40 51" Rear Projection...
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Dec 28, 2009 | Sony KP-53HS30 53" Rear Projection...
I have a KP-61HS30 and the picture is blurry or double
This is the stk392-??? ic's are bad. the repair can cost about $250 to 300 to fix by a pro. If you are a diy er you can replace the ic's on the board i have written an article on how to do this.
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Sep 02, 2009 | Sony KP-41T65 41" Rear Projection...
I have a sony projection tv KP-46WT500 and have red/green shadows around the people plus some double word image that are red & green. On the tv guide the station #'s are double and green and red.The...
Replace Both of your convergence ICs STK392-??? they are big black ICs will have part number on them also CK pico fuses they look like resistors but are fuses they will be yellow or green will be around ICs.
Aug 08, 2009 | Sony KP-46WT500 46" Rear Projection...
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
KP-61HS30 Sony TV turn pink and green text is bowed
Check out CONVERGENCE GALLERY . If you see your symptoms you have a problem in your convergence amplifier circuits. Typical Sony Convergence repair requires disassembly for replacement of 2 ICs, sometimes a fuse or 2, then TV is like new.
It is much more complicated than changing batteries on your remote. Many consumers try unsuccessfully to do a convergence repair. I recommend finding someone competent to do it for a reasonable price. Typical repair shop charges may be from $400 to $650.
If you are in the Calgary area, call me. More reasonable rates.
easyab
Jul 31, 2008 | Sony KP-41T65 41" Rear Projection...
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-61HS30 TV Logo
119 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
