Question about Fellowes P600C-2 Shredder
Motor runs both forward and reverse, but cutters don't turn
I can hear the motor run but the cutters don't turn. My main problem is that I can't seem to figure out how to separate the cutter tray from the top even though I removed the 6 screws.
  • 5 more comments
  • Anonymous Jan 26, 2008
    yes and i am looking for spare nylon gear! it's easy to repair. why don't they supply parts, i will have to scrap that stupid shredder, what a good environmental solution!!
  • Anonymous Feb 24, 2008
    Yes, it is definitely a broken gear. I've taken mine apart (after finding that screw hidden under the label). I haven't contacted Fellows about getting a replacement part, but I expect to find there are none, even if I can find someone to actually ask.
    If anyone does come up with a source of replacement parts, please let us know. Call me at 503-289-6363.
    Rick
  • MrFixItMaui Jun 08, 2008
    Shredder motor runs forward and in reverse, but cutting blades do not. Took it apart and found one tooth on nylon gear broken.....replacement parts???????
  • Anonymous Jun 09, 2008
    I contacted Fellowes and there are no replacement parts available for the P600C-2 shredder.
  • ggetter Jul 02, 2008
    Shredder is jammed. I can't seem to get it apart. I've taken out the screws but the top will not separate.
  • Anonymous Aug 23, 2008
    I have the exact same problem. Took out the six screws and, thanks to your post, was able to find the seventh and get the cover off. I didn't take my gear assembly apart but am sure, based on the comments above, that I have the same issue.
  • Anonymous Apr 10, 2009
    I have the same problem. Motor runs, but the cutters do not turn. Opened the unit. The main drive gear is plastic and one of the teeth is broken off.
How about a hidden 7th screw? If you look at the sticker on the underside where the bar code is you may see a dimple like there is a hollow space under it. If you can't see it, rub your finger over it to find the hole. Just stick your phillips screw driver through the sticker to get access to this last screw. As for the motor working both directions but the cutter doesn't turn it is most likely a broken nylon cog on the drive gears within the white plastic housing at the end of the shredder. There are 3 or 4 gears - all nylon (plastic), my unit had one tooth completely broken off and the one next to it was worn. I am looking into finding parts but I'm not having any luck so far with local service centres. I have a call into the fellowes main 1-800 number to see if they can help. On reviews I have seen this is a common problem. One reviewer was told they use nylon to reduce noise, but of course it isn't going to last long, especially if you ever jam. Nice metal cutters but the weak link is the drive gears that you can't see.
Posted on Dec 07, 2006
Minn kota e drive
Need the model #. During the mean time(back in the buggy farm) trace the wiring & check the control switch operation including the connections. Trial & error-swap the polarity on the main power feed to motor control & check ops. Motor runs forward, motor OK.
May 21, 2014 | Boating
My ativa hs 2000 paper shredder will only run in reverse
If the motor will only run in reverse and, you are stating that all the buttons are working. then most likely, internally the motor has burned out try tapping the motor lightly with a small hammer while the shredder is plugged in and on in the forward position. if the motor begins to move it will lead you to the answer of a shorted out internally motor.
Oct 15, 2012 | Office Equipment & Supplies
Infoguard-10 sx100m motor runs, sounds like gears are turning , goes both forward and reverse. i cleaned all of the teeth, looks clean, but won't accept paper. i am handicapped and am having a hard time...
When motor is running, look to see if the cutters are turning. The cutters can be seen by looking into the throat of the shredder. If the cutters aren't moving, the gears may have been stripped and shredder needs to be repaired or replaced.
Good luck...
Apr 15, 2011 | Cross Infoguard Shredder SX102M
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
My PX110MX will not turn on, if I hold the on/off button down I can hear the reverse motor run but the forward motor will not run.
If you can hear the motor run that is a good thing....however there is only 1 motor...it does both jobs running backwards and forwards....if it runs backwards the motor is "probably" ok and the problem is with the pcb inside...call Royal at 1-800-524-0799 for parts assistance.
Feb 02, 2010 | Royal VF1000MX Shredder
Motor and cutter do not rotate - strip cut model
Soak the clog with dishwashing detergent and a little bit of water overnight. This should dissolve the paper.
Jan 07, 2010 | Fellowes Manufacturing C220 (Strip-Cut)...
Blades rotate twice but stop-motor continues to run, both forward & reverse mode its the same. Have tried to oil, unblock, run forward & back but to no avail. Can anyone help
Is the motor just humming after the 2 rotations? If you are over oiling the unit, tha shreds will soak up the oil and start sticking to the blades and begin growing a paper tumot in side the cutter shroud, whish in turn will start to slow down and jam the cutter asm and motor. Best to take apart and thoroughly clean.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 01, 2009 | Office Equipment & Supplies
Motor runs but document will not feed into machine.
oil the cutters, make sure shreddar is mounted properly on the bin, reset the shreddar unplugging it and then plugging it back in, make sure the bin isn't full, if so then empty it.
Apr 06, 2009 | Office Equipment & Supplies
Shredder Beeping
The motor would always turn the cutters.
You likely have a broken chain or a loose gear on a shaft. If you hear the motor running and the cutters are not spinning something in the drive is broken. Likely the chain.
hope this helps.
Mar 20, 2009 | Dahle High Security 20634EC Shredder
Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Jun 21, 2007 | Royal 150MX Cross-Cut Shredder
Fellowes P600C-2 Shredder Logo
826 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
quennie732
Charles T Nevin
Charles T Nevin
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
