Question about Pioneer Audio Players & Recorders
Pioneer ev21dvd displays a power err message then shuts down while playing cds or dvds
SOURCE: Plays CDs but not DVDs
Melisha, I had a similiar problem. Go into the onscreen menu with the remote using the "ACTION" button on the bottom left of the remote. Using the arrow keys in the center of the remote, move to the menu for the audio processing. It will have menu items for DTS, Dolby Digital etc. Change the menu parameters for the "Down conversion" to "yes", get out of the menu mode and see if your DVD works again. If not, make sure there is no DVD or CD in the player, and press the "open/close", "pause" and the double left pointing arrow buttons all at the same time for about 5 seconds until the display on the DVD player says "INITIALIZE". This resets your machine. I hope this helps you.
Posted on Mar 22, 2007
snakehead
  • 1074 Answers
SOURCE: will play dvds but not cds
your DVDneeds to be adjusted take out the tray turn over the lens there are two shiney screws to the bottom of the lens the one to the right is for dvd and the one to the left is for cd turn to adjust. good luck.
Posted on Apr 06, 2007
  • 319 Answers
SOURCE: Kenwood DP-MH5 CD Player won't
CDs can be removed but you must use great caution not to break or bend mechanism components. Its better to have unit serviced by pro/tech
Posted on May 10, 2008
tech48
  • 624 Answers
SOURCE: pioneer xv htd520 won't play dvds
This is a common problem for this model. It has a memory IC that must be replaced. This is a surface mounted IC that requires exceptional soldering skills to replace. I work at an authorized Pioneer service center and have repaired a good number of these for this exact problem. Unless you have great soldering skills it is not something that should be attempted to do yourself, it can cause permanent damage to the board if not done perfectly.
If you have the proper skills and soldering equipment I will be happy to give you the Pioneer part number so you can replace it yourself. If not, then you really should just take it to a service center and have a professional do this.
Let me know if you would like that part number.
Dave
Posted on Dec 12, 2008
petraman7
  • 1175 Answers
SOURCE: Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
Posted on Jan 22, 2009
My Lenovo g550 model slimtype dvd ads8a4s is playing CD's only not DVD's, it does not recognize them. What can I do?
Please double check your drive. GOTO My computer and there you will see disk partitions and optical drive type.. I mean your DVD drive does it says DVD or CDROM? Now if thats DVD then you need to check software you are using.. Its better if you can download VLC
Player thats the best software I have tried.. and no region issue.
Jan 09, 2015 | Lenovo Computers & Internet
A word Err appears on sony CDP-CX53
The message is its way of telling you it is shot.
Feb 13, 2014 | Sony CDP-CX53 51-Disc CD Changer
The unit will not play dvds but does play cds
shut it down and restart it. It has to do with the settings. Did You configure it when You first hooked it up?
May 24, 2009 | Philips DVD795SA Multi-disc DVD Player
1992 6 disc cd changer not working
Are you placeing cds face up or face down in the changer, some cd changers will only play with the cds face down.
Oct 26, 2008 | 1992 Lexus Es 300
Pioneer XV-DV434 DVD/CD Player
unplug it from the wall for a while, if that don;t do it then it will have to be taken apart and checked for the reason
Oct 11, 2008 | Pioneer DV-350 DVD Player
DVD MALFUNCTION
DVDs and CDs are formated with regional encoding 1-6. If your player does not support the format, it will not play the disk. You might try looking up your brand/model player online to see if it has a regional patch code which you can enter via remocon.
Sep 07, 2007 | Pioneer VSX-D608 Receiver
try it on diff plug or open it must be sme wire has been broken
Aug 01, 2007 | Pioneer DV-444 DVD Player
Will play dvds but not cds
Apr 02, 2007 | Pioneer DV-C503 Multi-disc DVD Player
119 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
