How to remove horizontal lines for dvd player
    President:
  • 1,952 Answers
This is a common problem and is either bad connections at the vertical Ic or a defective IC. Look for a small flat Ic attached to a heat sink with 9 pins or so. It should be marked LA7837 or similar. Resolder the pins and try again. If that fails, replace the chip. That should fix it. You may also need to replace some capacitors in the same circuit if the picture lookes stretched or otherwise off. The Ic should be labeled on the board as ICxyy. Capacitors in the same circuit will have the designation Cxyy. Change the Caps that have the same x designation.
Posted on Nov 07, 2008
Power ON DVD, horizontal lines running on the TV screen. How do I get the horizontal lines to stop running and for me to view the screen to possible reset the DVD player.
Check video plugin to see if connect good on both tv and dvd player. You might try unplugging and re plug. If that doesn't help you might try another plug wire not sure if you have rca or HDMI plugs.
May 14, 2015 | Jwin Electronics JD-VD138 DVD Player
The screen on the dvd player has lines going across it. This does it with or without the cd
The horizontal line connection for that particular line has lost contact or the diode for that line has burnt, in either case, a new LCD would be required.
Dec 19, 2009 | Durabrand DUR7 Portable DVD Player
Main screen horizontal black lines
look for a button on the remote cont marked n/p or np and press it hope that solves your problem
Jan 16, 2009 | Haier Portable DVD Player PDVD7
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Thin white line on screen
this is a screen fault... this should be sent to the maufacturer for repair/replacement if still in warranty
Sep 28, 2008 | Durabrand DVD-1002 DVD Player
Insignia vehicle installed dvd player problem
You have a damaged LCD inverter board. The unit can now be used as a player only and you'll need to connect it to the A/V outs to see video clearly and without the lines.
Dec 23, 2007 | Insignia IS-PDVD10 Portable DVD Player
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
Horizontal lines from dvd player on tv
connect the dvd to another tv if it gives the same problem,change the video connecting wires.
Mar 12, 2007 | Sanyo DS27820 27" TV
DVD recorder -- displays blue horizontal lines only
Most DVD players today are very inexpensive.
If your system is working well otherwise, I suggest purchasing a new DVD player. Try that solution. If for any reason it does not work then another problem may exist which may include an issue with your TV!
May 02, 2017 | Samsung DVD-R4000 DVD Recorder
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
