Question about Haier hwr10xc6 Air Conditioner
Hot air i went into my room tonight and it was hot! the ac was blowing only hot air out and the decimals were stuck on 91 i touched buttoned it back down and in one second it goes right back to 91 and blowing hot. what is this? is it finally broken? thanks
  • 108 Answers
Sounds as if a Capacitor has failed. You must remove the face plate of the unit and find this capacitor. It will be gray in color, oval and have 3 terminals on top. Take this to a supply house and get another with the same ratings. This is important! Replace this and your problem should be solved. Remember to replace the connections as before.
Posted on Nov 07, 2008
In AC mode the cooler fan doesn't turn on and after a little while the warm air starts to blow instead of cold air. Any ideas
Sounds like a bad or stuck reversing valve. Typically r.vs. are energized in cooling, verify 24 volts to valve, if yes , bad valve
Sep 30, 2016 | Whynter ARC-14SH ECO-FRIENDLY 14000 BTU...
The heater is blowing cold air
Check heater hoses running from the engine to the cabin. and check if heater switch works
Nov 28, 2012 | Cars & Trucks
Aiconditioning blows hot air Ford Focus 2004
Your valve that shuts off the hot water to your heater core is not closing.Your AC is running but it is trying to cool down 200Deg. air.May be a issue with the heater/AC contol in the dash or the mixing valve stuck open.
Dec 31, 2009 | 2004 Ford Focus
Drivers side AC goes hot, passenger side still blows cold
You have a vent control actuator motor stuck,or gone out.
Aug 10, 2009 | 2007 Chevrolet Silverado 1500HD
2000 Mercury Grand Marquis will only blow hot air when ac is on. The ac system does work lines get cold but will not blow nothing but hot air. Has automatic climate control system. Will direct air from...
needs re-gassing because one line should be hot (feed) and the return cold , This is a specialist job do not attempt to do it yourself because its extremely dangerous with very high pressures involved
Jun 21, 2009 | 2000 Mercury Grand Marquis
When on AC the air blows hot, when on heat the air blows room temprature
This is a wiring issue or you have a heat pump and the reversing valve is stuck.
Jun 03, 2009 | Honeywell Electronic Programmable...
Stand alone AC blows cool air but does not cool the room
send tank capacity.model mail me
Oct 09, 2007 | Heating & Cooling
Blowing hot air
Water in the pan is normal, this is the humidity removed from your space. Pan must be emptied regularly. If the unit shuts down after 15 minutes, you may have a blocked hot air duct. Make sure it is flowing freely. This includes makeup air from outside the room to replace that blown outside by the AC.
Jun 24, 2007 | Sunpentown (EHW10268) Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
