Panasonic CT-27HL14 27" TV
Problem for Panasonic CT-27HL14 27" TV
Panasonic CT-27HL-14J Chaisis BP416
By highjinks on Oct 16, 2006
The power button lights up but no sound or picture. Any suggestions on where to start to look? TV has hardly been used since bought.
Solution #1
posted on Feb 21, 2007
Somewhat Helpful)
Know enough
Rank: Apprentice
Rating: 80%, 4 votes
Unplug the set for 2 minutes, that resets the registers in the micro ;).
Comments:
Feb 21, 2007
- Unplug the television for 2 minutes, that will reset the registers in the micro ;).
Was this helpful?
Yes
No
Solution #2
posted on Oct 17, 2006
Somewhat Helpful)
Coil
Rank: Wiz
Rating: 81%, 300 votes
I agree with Jomaru.
You must not delve inside unless you or a friend are familiar with where mains or high voltage exists.
The first place to check is a reservoir capacitor with about 350 Volts DC on it, probably located near where the mains lead comes in.
If the voltage is present and no very high pitched whistle can be heard, then the fault is in the line timebase. See other fault reports for more information on this.
If the 350 V is absent, there may be a fuse which will blow because one or more rectifier diodes have failed (usually Short Circuit).
Was this helpful?
Yes
No
Solution #3
posted on Oct 16, 2006
Somewhat Helpful)
techman
Rank: Guru  Panasonic Expert
Rating: 86%, 7668 votes
Do you know how to work on solid state electronics? if not then Im sorry to say you will need to get the assistance of a local tech who is experienced. As these sets are solid state and there are no user servicable parts inside. Good Luck
Was this helpful?
Yes
No
Solution #4
posted on Feb 23, 2007
Somewhat Helpful)
relectronics
Rank: Wiz
Rating: 83%, 57 votes
i had encounterd different kind of models with a same problem. I could suspend that the problem is fusable resistor or an open diode (signal diode).
Was this helpful?
Yes
No
Solution #5
posted on Mar 08, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If the power light is on then the power supply must be active. In many cases the line output transistor may have failed but this is usually accompanied with the power supply trying to switch on and the overload protection circuit switching the power supply off again. Try unsoldring the collector of the LO transistor and switch on the tv and see if the tv powers on
Solution #6
posted on Feb 27, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
check for leakage or shortout horizontal amplifier i.e transistor supplying the fly back transformer.if u get me the circuit diagram I'll give u the exact component
HHK. hhcombe@yahoo.com
Solution #7
Not Rated)
jomaru
Rank: Guru
Rating: 87%, 493 votes
You have a few places to check,check the output transistor for a short ,if he went bad it likely opened a fuse or a safety resistor ,You could have a problem in the power supply and only some of the volts supplies are working,there are measurements that need to be done and parts to check with a meter if you are familiar with tv service you have a place to start but if you are not too familiar be safe and call for assistance from a servicer.
Comments:
Oct 16, 2006
- Your rating response is important too.
Was this helpful?
Yes
No
Popular Solutions for Panasonic CT-27HL14 27" TV
Questions and Unsolved Problems for Panasonic CT-27HL14 27" TV
Do you recommend Panasonic CT-27HL14 27" TV?
Answer
Answer
problem - cant find the proper setup code to correspond with the comcast digital adapter
Answer
The screen is completely black but there is audio through only the basic cable channels (2-13 - even... (More)
Answer
Fixed the 5 blinks $240.00 played for 2 hrs. then shutdown... now they want $260.00 more for the 1... (More)
Answer
can you please send me a following sematic manual to my e-mail manufacture:panasonic model... (More)
Answer
I go the the setup menu and go the the memorize function but it will not memorize the channels? Is... (More)
Describe your Standard Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in Sedona, AZ
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
