Question about Maytag Neptune MDE5500AY Electric Dryer
Banging noise as dryer spins, wore hole in side of dryer
When the dryer runs, it makes a banging noise like a large zipper is in the dryer. It has even worn a hole in the left side of the dryer where something is hitting.
  • blacksa Nov 13, 2008
    Seems that one of the fins inside the tumbler has come loose. Not sure how to take the top of the dryer off to access the outside of the drum. Any suggestions?
  • Anonymous Nov 25, 2008
    One of the fins came loose on the tumbler inside. How do you access to tighten the fin. The model number is MDE5500AYW.
  • 41 Answers
I need to know your make and model number in order to give proper advice. Joe
Posted on Nov 18, 2008
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
How do I fix a ge top load washer that's making a loud banging noise while agitating?
There is either a balance issue or a damaged spring. Usually all you need to do is open the washer (make sure it is OFF) wait for it to stop spinning... then look for clothes bunching up on one side. Take some out ad move them around.
Sometimes putting in to many or too few items will make it harder to resolve. Items like large towels or several towels, sheets and such will hold more water and be heavy until the water starts to pull out.
Oct 09, 2014 | Washing Machines
I have a Maytag Intellidry Gas Dryer Model MDG8057BWW. When it runs, it makes a banging sound on the left side. I can feel the banging with my hand on the frame. What can this be? Is the dryer safe to...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 15, 2010 | Maytag Dryers
Dryer is making a banging noise? Sounds like
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 17, 2010 | Maytag MDE9700AYM Electric Dryer
Dryer makes banging noise
heatman101
uioiotusdds
Jan 30, 2010 | GE DBVH512GFWW Dryer
Spinning cycle
Depending on what washer you have, what model. Some are easy to open some are not. But there is something between the inner and outer tub. The inner tub is where you put your clothes in with holes in it. The outer tub holds the water in the machine. I've pulled things that you wouldn't believe out of there.
Oct 20, 2008 | Kenmore 24032\24036 Top Load Washer
White knight tumble dryer making banging noises when spinning
I have this banging problem, it sounds like a plastic ball rolling about inside it
Aug 25, 2008 | Dryers
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
basscat, you first remove the door by removing the screws from the hinges. The door will lift up a litte and pull off. Next remove the spacers on the other side. Now the front panel will pull out from the top. There will be two 1/4 inch screws with latches on each side of the frame, remove these and the top will lift up. Now by holding the door switch and starting the dryer, you will be able to see what is banging. Once you determine that, you can remove the bulk-head, should be 4 screws, be sure to unplug the door switch. Unfasten the belt, remember the configuration and remove the drum. You are now able to get at the insides. Catriver..post back.
Oct 02, 2006 | Maytag MDG9206 Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
261 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
