Question about Sanyo DS31520 31" TV
Funny half screen problem
I do not know the origin of the problem, but my television has been working great until recently. Now when I turn my television on I can only see the upper half of the screen and the shapes are distorted (people appear to be like midgets). The bottom half is black. The wierd part is that the upper half gradually gets bigger and bigger pushing down the black part and over maybe about 45 minutes I am able to watch the TV full screen or maybe with a half-inch left on the bottom. What is happening and is there a way (ie setting to change) to fix this?
  • twistedt Nov 12, 2007
    My problem is almost the same. I turn on the tv and it has sound but only half of the screen for about 5 seconds then it is gone. It did have sound but now it doesn't. I looked for bad solder joints but unable to locate any. Does any one have an idea where I should start?
    Thanks
Problem with sanyo ds 13630
Posted on Oct 26, 2007
    President:
  • 3,130 Answers
Nope, Sorry to tell you, there is most likly a coupling capacitor or the vertical sweep IC itself could be defective. Although if you have had some sort of solid state Printed circuit board training, this should not be to hard to find, with a can of freeze spray. Unfortanatly this set has no user replacable parts inside of it, as everything is soldered into place and there is no easy fix. Although depending on how old the set is, is going, Im sure, to determine if you want to invest any cash into this thing. Without any training it would be a crapshoot Im afraid! So stay safe and seek the assistance of a pro. Good Luck Please do not forget to rate this!
Posted on Oct 16, 2006
    Scholar:
  • 68 Answers
The coupling capacitor techman mentions is probably one in series with the frame scan coils which may be leaky. There are probably several components in the frame output circuit which are to shape the current waveform to an `s' shape, to give a linear scan down the tube face. slight changes in these components with temperature will affect the linearity of the vertical scan. There may be small adjustable potentiometers to set, but be sure you know the right ones. A meter on ohms may be useful to check all these components. I do not think it is the chip. There may be poor soldered joints.
Have a large black box in center / lower half of screen - How do I get rid of this?
check your CC settting, Closed Caption and make sure it is turned off..
Sep 21, 2014 | Televison & Video
Maybe you got dried capacitors near the vertical IC or the IC himself are damaged you need to be atech for make the rapair because is dangerousli make it
Jun 02, 2009 | Sanyo DS31520 31" TV
ViewSonic N2700 Blinking power button
replace the power supply, buy it on the internet by looking up the model number on the power supply. I have this tv and it did this until I ordered a new one. it runs hot and has a loud fan.
Jun 14, 2008 | ViewSonic N2700W 27 in. HD-Ready LCD...
Plasma TV Background noise
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
May 28, 2008 | HP PL5000N 50 in. HDTV Plasma Television
My Screen!!!
hi
restatrt your system and press F8 KEY UNTILL U GET MENU.
then go to best configuration or safe mode.
then if u get normal window change your display resolution to 800x600 or 1024x768.if u get differ reso.
restart in normal mode u get good display in original content.
pls notify this solution
Mar 23, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Green Tint on half of the screen
This is most likely a defect in the optical unit (about $1500.00 part). If out of warranty probably will just have to live with it. Those op units are also hard to get.
Jan 15, 2008 | JVC HD-61Z575 61" Rear Projection...
Rolling menu on screen
sounds like you have it in demo mode. In the menu will have it labeled demo on or off
Dec 09, 2007 | Zenith B32A24Z 32" TV
Top half of screen blacks out
Today, after speaking to the Sansui Manufacturer representative from Japan. He stated that all you need to do is to turn off the closed caption from the TV remote and not the DVR remote. Black screen can occur at the top half or the bottom half of the screen depending on how it was originally setup during installation. Try this and hopefully this fixes the problem.
Oct 06, 2007 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Screen just split in half
Is the tv still in warranty? The problem is the upper buffer board, it's a small board that controls the upper portion of the screen. You will have to consult a service center to get it, it's very easy to install
Apr 15, 2007 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
Sanyo DS31520 31" TV Logo
124 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
