Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Wireless adapter wpn511
Can i use a netgear adapter to a lynks router
with-out the cd-rom
  • 6,487 Answers
Yes, youc an use just download the software from the Netgear web site and that should do the trick...
Posted on Nov 07, 2008
My Motherboard Model is : A32GV11C and i have a problem with lan driver definition. and i need an easy installation for the mentioned model for the ethernet controller
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
Realtek RTL8139/810x Family Fast Ethernet NIC http://download.cnet.com/realtek-rtl8139-810x-family/3000-2112_4-96337.html
hope this helps
http://majorgeeks.com/Netgear_WPN511_d4753.html
Netgear WPN511 WHQL 1.2 Latest WPN511 wireless adapter drivers
hope this helps
Apr 14, 2011 | ASUS SiS Chipset P4S333-M...
Having trouble uninstalling netgear wpn511
Need your version of MS Windows (or are you using Linux or Apple OS?), anyway, assuming
MSWin XP or WinVista or Win7,
start > control panel > add or remove programs > (L-click) Netgear software > (select) "Uninstall"
but if these vanilla instructions have been tried & aren't working, you may need to do a "system
resore" to a recent system configuration that worked well, then uninstall there, then re-install
all the stuff you're missing by doing a system restore...... if you've installed alota stuff recently
(like me) this could be very painful, and you won't know how far back to go until an uninstall works.
From the Netgear WPN511 RangeMax reference manual
avail from: ftp://downloads.netgear.com/files/WPN511_UM_03Feb07.pdf
Removing the WPN511 Software
If necessary, you can remove the wireless adapter software in these two ways:
• Navigate the Windows Start menu to the WPN511 Wireless PC Card program group, select the
uninstall option, and follow the screen prompts.
• Navigate the Windows Start menu to the Control Panel Add or Remove Program item, select
the WPN511 Wireless PC Card option, and follow the screen prompts.
If your system is acting unreliable and/underperforming in other ways, suspect a virus/worm/trojan
and clean out your system with Avast!/Norton/AVG/Kaspersky/McAfee, etc. then try the
uninstall again.
Dec 27, 2010 | NetGear WPN511 RangeMax Wireless PC...
NetGear WGT624 Wireless Router
No. This is referring to the free space on the CD itself. As this is a commercially stamped CD-ROM it is gonna report 0 bytes free as you are unable to add more data to the CD. The driver on the CD should install properly.
Jan 25, 2009 | NetGear WGT624 Wireless Router
Netgear wpn511 computer not detecting
mccree08 on Nov 26, 2008
i have an acer aspire 5315 notebook 3 months old i purchased a netgear wpn 511 rangemax wireless card to help with my signal.the software installed fine but when i look in the device drivers i dont see the card as if the computer isnt recognizing it. there are also no lights on the card when plugged in. is my express card slot not working?
Wednesday, August 05, 2009 09:55
Hello mccree08,
The installed network adapters can be viewed in the windows device manager which can be accessed through the windows control panel as follows:
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
•In the Control Panel, Select Device Manager
•In Device Manager, Select 'Network Adapters'
The netgear wpn 511 adapter will appear there if it is correctly installed.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Nov 26, 2008 | HP ProCurve Wireless 802.11b Access Point...
Cant connect wirelessly
Yes u have to buy a netgear N dongle ...
Because N works on 5 ghz and G works on 2.4 Ghz
You can buy netgear WN111v3
Nov 19, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I have an Acer Aspire 8.9....and I need to know what type of router I need to go wireless. I purchased one from Netgear, but it has a disc that must be installed and adapter that has to be used {with...
Aspire one does not have a CD/DVDROM however you can use another computer to be able to setup your router. You can probably ask a friend to use his/her laptop that has a CD/DVD ROM. After setting up the router, you can connect your Acer Aspire by letting it detect the wireless signal and connecting to your router wirelessly.
**You can also try to insert the installer disc on another PC and copy all the contents of the CD/DVD installer of the Netgear into a USB flash Drive. Plug the USB flash Drive into your Acer then run the setup file inside and follow the instructions.
Oct 26, 2008 | Computers & Internet
Cannot connect to my laptop with a built in wireless.
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Jul 13, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
How to install with out the cd?
Are you using XP? You shouldn't need the CD.
http://www.netgear.com/Home/Products/Adapters/GWirelessAdapters/WG111.aspx
Gives you information about the USB adapter.
http://www.netgear.com/Products/RoutersandGateways/GWirelessRouters/WGR614.aspx
That gives you information about your wireless router.
Do you need a manual to set this up? It looks like there are different version of this wireless router. Which one do you have? This can be identified on the package or the unit's bottom label.
Once we know which version you have we can continue.
Dec 11, 2007 | NetGear WGR614 Wireless Router
Problems with netgear software or possibly worse
Windows XP:
Windows XP:
Getting an intermittent wireless connection can be attributed to the following factors:
a. 2.4 GHz wireless interference
b. Wireless settings of your router
c. Location of the devices
d. Obstacles
You may also refer to the common causes of interference:
Window in brick wall 2dB
Metal frame, glass wall into building 6dB
Office wall 6dB
Metal door in office wall 6dB
Cinder wall 4dB
Metal door in brick wall 12.4dB
Brick wall next to metal door 3dB
In order for us to isolate the problem, please refer to the steps below:
1. Avoid obstacles.
a. Try to move the router to different locations in order to get better connectivity. We suggest placing the router on high location to avoid obstacles that may be blocking the signal.
2. Reduce wireless interference in the area.
a. Try to move the router away from devices that are operating on 2.4 GHz frequency like your cordless phones and microwave ovens.
b. Try to move the router away from windows. Windows let in interference from the outside world.
3. Adjust the wireless settings on the router.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. For security reasons, the router has its own username and password. When prompted, enter admin for the Username and password for the Password, both in lower case letters.
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab.
e. Change the Network name or SSID to your preference.
f. Change the Mode to g and b only.
g. Change the Channel to 11, 1, 6 or 9.
h. Click on the Apply button.
i. Reconnect your computer to the wireless network and see if it fixes the problem.
Note: If the problem persists, you may need to upgrade the firmware of the router.
4. Upgrade the firmware.
a. Please verify the router version and model either underneath or at its side panel.
b. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router.
c. Click the appropriate version of the router.
d. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. If your computer has wireless connection, then please disable it first.
e. Before upgrading, please write down all current settings since you need to enter them manually.
f. Using the computer hardwired on the router, please access the router’s setup page again by going to http://192.168.1.1 or http://www.routerlogin.com/basicsetting.htm
g. Click on Maintenance and then Router Upgrade.
h. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.
i. Please wait for the router to reboot.
5. After a successful firmware upgrade, you need to reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards.
The router can be reconfigured using the setup CD or by manual configuration.
Nov 08, 2007 | NetGear RangeMax 240 WPNT121 (WPNT121NA)...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
49 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
