Question about Panasonic PT-51HX40 51" Rear Projection Television
Panasonic projection hdtv 51"
My television screen is now blank down the middle, and what should be on the left side of the screen is on the right; and what should be on the right is on the left. Also there are green vertical lines. The television is four years and 5 months old. Just out of the extended Best buy warranty.
  • 3 Answers
Sounds like convergence amps went bad its not a cheap 100.00 repair but will run about 300.00 to 400.00 to repair use only orginal replacement parts might be stk362-110 DO NOT SUB
Posted on Oct 16, 2006
51F59A red screen all the time
1. entire grill below front screen must come off (usually held in place by screws in back on either side.)
2. locate and remove inspection plate dead center behind it.
3. Locate small black plastic block with 6 black controls built in; three (look carefully) left to right are focus--DO NOT TOUCH THOSE.
The other three are Screens and will be marked with tiny letters r g b (red, green, blue) and green is always middle.
Locate the red screen (not FOCUS).
With set on adjust red down just slightly(usually less than 1/8 turn.
Since the set will be on TAKE CARE NOT TO TOUCH ANYTHING INSIDE THE SET WHEN YOU DO THIS.
IF YOU HAVE QUESTIONS ASK BEFORE YOU TRY THIS.
Nov 20, 2011 | Hitachi 51F510 51" Rear Projection...
Left side of sreen is blurry/halo effect. Right side is normal. Magic focus stops when it gets to green and flashes green number 5 on bottom left of screen. (Hitachi 2003 51" projection HDTV)
SET uses two of the STK-392-150 convergence chips for this, both need to be replaced and set adjusted.
Parts cost on EBAY will be under 25 dollars. I can help if you are do it yourself person. A shop will get 250-300 for this but you can do it for much less.
Can I assist you?
SD TECH
Sep 15, 2010 | Hitachi 51F500 51" Rear Projection...
Panasonic HDTV from 2001. 51
I had the same problem and fixed it myself with a kit from www.TvRepairKits.com. Works great now.
Jan 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Toshiba 51h84 "Crooked Picture"
Still the convergece prob.The FL231 fuse near the FBT transformer it dead.The square fuses 3 rectangles fuses.One in the middle.
Aug 09, 2009 | Toshiba 51H84 51" Rear Projection...
Concave picture
sounds like the bulb is on its way out, they can be replaced for about 100 bucks.
Jul 25, 2009 | Philips 51PW9303 51" Rear Projection...
Panasonic PT-53wx53G 53' projection tv problem
was your tv hit hard,a non magnetically shielded speaker set on top or under it?
Nov 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Nov 07, 2007 | Toshiba 51H84 51" Rear Projection...
51F510 Screen is split in two
requires service, horizontal fold over and possible other problems to come .
Sep 13, 2007 | Hitachi 51F510 51" Rear Projection...
Projection tv
The windex/water was wicked up into the screens by capillary action, I have always replaced them and havent been able to clean.
May 23, 2007 | Hitachi 51G500 51" Rear Projection...
Panasonic PT-51HX40 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
